I got curious and wanted too check out the ohm reading on my sub, so i just disconnected the speaker cable from my amp, then put the probes of my dmm on the the positive and negative cables. The dmm says its wired to 1.8-2.0 ohms. Is this normal? or by some mistake do i have a d4 ohm sub? I have a SS RL-p 18 d2, wired in parallel to my sundown saz1000d. thanks!
box rise.........
to get a proper reading take the subs out and check also it might move up or down cuz even the slightest movement or vibration can cause the impedance to rise
RIP The 03 prix!
New Ride
2003 Chevy Tahoe Z71
4 DC LVL 4 18s (2 currently installed)
2 DC PAI.2000 (1 currently installed)
1 DC PAI-120.4
How many times do we have to go over a DMM measures DC resistance, not impedance!!!
And box/impedance rise has nothing to do with what you are reading with a DMM!!
Measure each coil right at the sub and see what you get.
Edited by bkolfo4
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
i was also wondering how i can better fit the cable into the terminals on the sub. since i am wiring it in parallel, i have to put 2 positive cables in one positive terminal, and the same for the negative. is it ok to shave some wire off to make it fit?
If you touch the leads together on the DMM, what does it read??
Current system:
Previous systems:
it reads 0. when i touch them. i went ahead and took the sub out and just rewired it just to be sure everything was solid, and put in some more bracing. but i did manage to put a small dent in the aluminum cone of my sub. :aggressive:
  • Who's Online   0 Members, 0 Anonymous, 16732 Guests (See full list)
