As stated make sure you have full intake, full exhaust then I'd start to save for a head/cam package with a MS4 cam, then that s10 will be moving its feet just a little quicker -- former 04' cobra owner here and believe me I had a lot of ls1 rivalries and many friends with them I felt like I knew way too much about them. Knew about 3 with the MS4 cam that ran stout as hell in fbody's and c5's. I know texas speed has head/cam packages and cam only packages available with mail order tunes for the ls1's.
Edited by TahoeDD
in that thread he was talking about an exhaust for an 03. in this thread it's a 97. Different trucks
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
<!--quoteo(post=963403:date=Feb 14 2010, 12:52 AM:name=tristan560)--><div class='quotetop'>QUOTE (tristan560 @ Feb 14 2010, 12:52 AM) <a href="index.php?act=findpost&pid=963403"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->Pics or BS. <img src="http://www.stevemeadedesigns.com/board/public/style_emoticons/<#EMO_DIR#>/bsflag.gif" style="vertical-align:middle" emoid=":bsflag:" border="0" alt="bsflag.gif" />
<a href="http://www.stevemeadedesigns.com/board/index.php?showtopic=57195&hl=" target="_blank">http://www.stevemeadedesigns.com/board/ind...c=57195&hl=</a><!--QuoteEnd--></div><!--QuoteEEnd-->
i say you start at ls1tech.com very useful info
I just started messing around with my LS1
I have an AFE air intake
truck coil packs
eaton posi
4.11 gears
magnaflow muff
and a diablo programmer
Night and day difference, with little invested
If i was into "power" with this truck, I would put a stick in it,stall, and long tubes.
Should see 320-330 whp through an auto.
as far as what i would do on a slight budget is
long tubes(also long is better for high rpm, shorties for torque, but on LS engines long is usually best)
lower gears(higher numerically)
1.6 roller rocker arms
mass airflow housing
TUNE!!!!!!
and if you want spray, these engines do wonders on nitrous
oh and colder plugs if you do nitrous... do all that and for under $1500 you should easily hit some 11's :D
1996 GMC YUKON 2dr
Eclipse cd5000
six- Soundstream T5 12's in 13^ft tuned to 30.4hz,43.04hz, and 53.53hz soundoff
149.8 on TL in kick,150.0 SEALED in kick 147.8 SB4
3 RF T5002's--------------going to 3 Soundstream DTR1.3400D's
two- Stinger sp1000's----going to two- BATCAP 4000's
2 140 amp alternators---going to 300amp Ohio Generator
2 runs 1/0ga, big 3-------going to 4 runs 1/0g + and 3 runs 1/0g -
MB Quart QSD 6.5's in doors---soon to come
my build log HERE!!!! check it out!
  • Who's Online   1 Member, 0 Anonymous, 1343 Guests (See full list)
