Nirvalica Posted February 16, 2010 Report Posted February 16, 2010 Maybe the video card + upgraded ram are pulling more power from the PSU then it is designed to deliver. Might be shutting itself off to save the PSU and possibly the rest of the computer from frying. I suggest a new power supply. Quote My Youtube Page. Check it out The "SAV" - Sub-aural Assault Vehicle Kenwood eXcelon KDC-X993 Image Dynamics CTX 6.5" Components Q-logic 6.5" kick pods CDT 6.5" CL-E6NEO Front door Midbass Kicker ZX350.4 Knukonceptz SS Karma 4 channel 6m RCA Fi Q 18" w/ brushed aluminum dust cap 7cu ft. ported box tuned to 28hz Sundown SAZ-1000D Iraggi 240 amp Amputator Alt Big 3 in Monster 1/0awg Second Skin Damplifier Lite on roof and front doors
Hotdog Posted February 16, 2010 Report Posted February 16, 2010 Maybe the video card + upgraded ram are pulling more power from the PSU then it is designed to deliver. Might be shutting itself off to save the PSU and possibly the rest of the computer from frying. I suggest a new power supply. Problem was there before the upgrade Quote (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
Team Bass-Hz(JIB) Posted February 17, 2010 Author Report Posted February 17, 2010 (edited) cool thanks fellas ill see whats up with it.....regardless ill be getting a new power supply so ill replace that and go from there caps looked good Edited February 17, 2010 by Team Bass-Hz(JIB) Quote Team Bass-Hz
BulletInjection Posted February 17, 2010 Report Posted February 17, 2010 That 1gb you did have in there before did you replace that stick as well or just add 3 more just like it? And is it the computer fan or is it the hard drive you hear? Some older computers and ones made by HP/dell/etc do not even come with internal fans aside from the heat sink on the cpu, some are also passively cooled... Well start off by running a DFT(I think thats what it is), disk fitness test and see if your hard drive is bad and if it passes then try pulling all your ram(if you had not replaced all sticks from my previous question) and placing just one in a slot to see if it runs fine, if it does then I would assume a dead stick... let us know whats up! Quote My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection
