tlee2 Posted February 17, 2010 Report Posted February 17, 2010 I need to figure out the cubic feet for my wall and im kinda clueless since this aint rectangular or a square. im trying to figure out my port size: 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
uhoh_45 Posted February 17, 2010 Report Posted February 17, 2010 draw a line from the bottom where the angle is and get your rectangular box and plug them in here then plug in the other dimensions in the wedge box 2 (same site) and then add the 2 together R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
tlee2 Posted February 17, 2010 Author Report Posted February 17, 2010 ok ill try that out 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
IH8PunkRok Posted February 17, 2010 Report Posted February 17, 2010 someone failed math? how about you find the triangular prism volume of the cut out area and subtracting from the total rectangular prism volume. you dont need a calc for that. honestly -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
tlee2 Posted February 17, 2010 Author Report Posted February 17, 2010 someone failed math?how about you find the triangular prism volume of the cut out area and subtracting from the total rectangular prism volume. you dont need a calc for that. honestly is that 1 half base x height x length or somethin like that? 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
IH8PunkRok Posted February 17, 2010 Report Posted February 17, 2010 is that 1 half base x height x length or somethin like that? exactly see you know how to do it yourself -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
tlee2 Posted February 17, 2010 Author Report Posted February 17, 2010 exactlysee you know how to do it yourself just had to make sure lol 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
