Crump Posted February 18, 2010 Report Posted February 18, 2010 I want these http://www.darvex.com/BTRP/XScorpion+Ring+...y+Terminal.html but idk if my stock wires will reach the bolts. Is there a way to extend the stock wires in order to solder the rings on? ? Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
BulletInjection Posted February 18, 2010 Report Posted February 18, 2010 I want thesehttp://www.darvex.com/BTRP/XScorpion+Ring+...y+Terminal.html but idk if my stock wires will reach the bolts. Is there a way to extend the stock wires in order to solder the rings on? ? You could use butt connectors I suppose... My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection
BeatBox Posted February 19, 2010 Report Posted February 19, 2010 why dont you get something like this, then all u do is cut the end of the stock wires and put them in the bettery terminal, no need to solder anything. just a suggestion. http://www.darvex.com/SPT53501/Stinger+Sho...y+Terminal.html
Crump Posted February 19, 2010 Author Report Posted February 19, 2010 why dont you get something like this, then all u do is cut the end of the stock wires and put them in the bettery terminal, no need to solder anything. just a suggestion.http://www.darvex.com/SPT53501/Stinger+Sho...y+Terminal.html That would make them shorter than they are, cuz right now the way my stock terms are they already have a ring but are at a right angle to the terminal. idk if i can explain it correctly. Thats what it looks like Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
