my small crx spl build
2 dd 9515's running 1 dd m3 STOCK 0-600 class 190 amp alt 2 runs of 1/0 kicker wire. 1 yellow top 1 kinetik 2000 tuned to 57 hz. In March I hope to have my dual alt set up in so I can run a 300 amp secondary alt just to the system so I can run in bigger classes with it and more power and different subs. I would love to build a 155+ system or something tuned low that gets insanely loud.
numbers?
www.bassproducers.com
TEAMS
TEAM BASSPRODUCERS, TEAM HERTZ (VA)
*Ranger System*
(4) 18" Kicker Comp
(4) 10" Kicker Comp
Dual Stinger Alts.
(5) Rockford Punch 200's
(2) Punch 100's
*Outlander System*152.6 DB so Far*
(8) TXX-APX12W
(2) AP-30001D'S
(2) AP-2004'S
(8) APMB6'S
(4) KHC2400'S
oh by the way that is an aq 3500 in the back not the m3. The box is also 8 cubes net with 2 8 inch tubes (pvc) didnt have areo ports.
numbers?
Not a clue yet. Tried out an epic 160 on it just to check the tuning did a 153 on that, but no clue on tl I'l have numbers up when I get back from the show on Sunday.
its nice seeing a CRX that isnt a one note wonder
looks loud
edit read tuned to 57 hz BOOOO
R.I.P!
(Nov-29-2009)
92 explorer
current build
looks loud
Ha ha ya this is only a one note wonder, but after the show Ima mess around with some ground pounder builds with 4 10s no emphasis on tl numbers just loud on the earometer.
i'd stick with 2 15s just tune lower and add more power :)
R.I.P!
(Nov-29-2009)
92 explorer
current build
Na I have fun putting in new shit I wil keep switching shit up and experimenting with the car.
If u really wanna go all out with the SPL side in the Rex, then I'd suggest making sum tubes for the woofers.. You'll see most of the loudest CRXs(also similar lower SPL class vehicles worldwide) around using the tubes now and are extremely successful doing so.
Pioneer AVIC-N2
