i'm have a feedback problem with my subs and amp ive had them in my car now for a couple of weeks and they where working fine but today i decided to take the head unit out of my wifes car and put it in mine and i got eveything hooked up and now im geting feedback i know the rca outputs are good becuse there is a system in my wifes car and it worked fine in there so im stumped and cant figure it out so does anybody have any ideals of what it could be
here is the headunit i just put in http://www.pioneerelectronics.com/PUSA/Pro...ers/DEH-P2900MP
here is the one i took out http://www.docs.sony.com/release/specs/CDX..._Spec_Sheet.pdf
1998 neon R.I.P 137.5 db's
Youtube videos http://www.youtube.c...tingarrett64067
2000 Eclipse
Headunit = pioneer avh-p1400dvd
Subwoofers = 2 DC audio lvl 2 12's
Amp= Vibe bass 5 1500rms @ 2ohms
​Single run of 0awg power and ground wire
( Big 3 wire upgrade comeing soon )
is it like a high pitched whineing noise?
Greg,
Triple C Auto Niagara Falls NY
Under construction
2002 Chevy Suburban
pioneer 8000NEX
3 Sets of ARC Audio 6000 components in custom front doors
2 Powerbass midrange in center council
4 Super tweets
2 Focal 900.6 6 channels
4 American Bass VFL Comp 15's (currently running 2)
DC 12.0k
DC Power dual alt bracket
2 XS Power D3400's under the hood
3 C&D technologies 110ah in rear
along with multiple runs of 0 AWG OFC
no its more of a low deep noise if i set my filters on my amp a little higher i cant hear it but when i turn them back down its clear as day im starting to think the rca jacks on the head unit have gone bad because i switched my old head unit back in to see if it went away and it did so is there any way of testing the rca jacks with a dmm to see if they went bad
2000 Eclipse
I don't think that's "feedback" ... It sounds like power line noise.. how deep is this "low deep noise"?
And no, there isn't really any way to test them with a DMM.
do you have a 4 channel hooked up? if now its ground noise you prolly blew up the radio you can try a ground look isolator sometimes it works some times it doesnt if it doesnt run a solid ground to something on the car ex. chassis sheetmetal ground the back of the radio then ground the rca shields on the subwoofer rca's
Greg,
Under construction
2002 Chevy Suburban
pioneer 8000NEX
4 Super tweets
DC 12.0k
the amp is a mono block and its the only one in the car i dont think i blew the radio up because everything else works im just getting the noise from the amp and subs just with this head unit when i putt the old one back in its gone thats why im stumped about it ill try running a ground from the body to the back of the head unit and see if that help's but im not for sure about how i would ground out the rca shield's on the subwoofer rca's
2000 Eclipse
the rca's are ran down the center of the car and the power down the driver side and the noise is clearly there at about 1/4 of the gain
2000 Eclipse
