the rca's are ran down the center of the car and the power down the driver side and the noise is clearly there at about 1/4 of the gain
25Hz? really .. damn... i still vote power noise..cheap RCAs pick up on everything...
Does it go up with you turn the HU volume up or does it go up when you turn the amp gain up?
On the bright side... If you can play that low, you can burp it at 25Hz whenever you want. lol
Edited by kdicetharappa
it dont go up with the head unit just with the amp gain i can still play music and every thing just fine im starting to think it might be my rca's they are pretty cheap there from wall-mart ill try a diff set out and see how it works out and im not for sure if it is 25hz it might be 30hz ill get 25hz test tone and see if i can play it and see if it sounds the same
1998 neon R.I.P 137.5 db's
Youtube videos http://www.youtube.c...tingarrett64067
2000 Eclipse
Headunit = pioneer avh-p1400dvd
Subwoofers = 2 DC audio lvl 2 12's
Amp= Vibe bass 5 1500rms @ 2ohms
​Single run of 0awg power and ground wire
( Big 3 wire upgrade comeing soon )
im not sayin you blem up the actuall radio you blew up the rca ground in the radio its a common thing with pioneers try a ground loop isolator if that doesnt work try to ground out the outside shield on the rca's behine the radio for the subs the noise should go away
Greg,
Triple C Auto Niagara Falls NY
Under construction
2002 Chevy Suburban
pioneer 8000NEX
3 Sets of ARC Audio 6000 components in custom front doors
2 Powerbass midrange in center council
4 Super tweets
2 Focal 900.6 6 channels
4 American Bass VFL Comp 15's (currently running 2)
DC 12.0k
DC Power dual alt bracket
2 XS Power D3400's under the hood
3 C&D technologies 110ah in rear
along with multiple runs of 0 AWG OFC
  • Who's Online   1 Member, 0 Anonymous, 1693 Guests (See full list)
