Alright i just bought a kicker solo x 12. Right now im looking for something to power it. Because my birthday is less then a month away so this amp or amps is what i was going to ask for. I was wondering if i should get 2 SAE 1200 or 1 SAZ 2000. I was wondering if this amp or amps would be enough power for this sub or not? I was thinking about eventually ugrading to 2 subs, so would it be smarter to buy the 2 1200's since the will be cheaper then the 2000? Plus i was thinking that the 2 amps would put out more power then just the one amp. What else would i need to run two amps? I really want to have some sundown POWER! because i havent heard anything but good things about sundown.
Also i would be getting the amps from dB-r.
Thanks in advance for any advice or opinions
Brandon
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
the coils on the sub are dual 2ohm
well with the 2 amps i would be able to run it at 1ohm if i had them linked for 2ohm's but running each amp at 1ohm correct? there for i could put around 2400 watts to the sub?
What ohm load would the 2000 be running at then?
1f wired in parallel one ohm.....do you have the electrical to support that amp tho?
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
So you have a single D2 Solo X 12, and if I looked at the specs right they are 5000peak/2500RMS .
I would go with the SAZ2000 and run it at 1ohm and you will see 2000watts (probually more with good electrical)
With two SAE1200 one per coil each amp would see a 2ohm load and be putting out about 600 watts to each coil for a total of 1200on the sub.
So ill let you do the math on that one.
If you go with a second SoloX down the road then maybe 2 SAE1200 might be ok, but then again running them at a 1ohm load would only give you 1200 to each sub and that is just about 1000 under RMS. So if it was me I would do 2 SAZ2000 or one per sub.
just my 2cents.
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
Stephen right now i dont have the electrical i need. i needed to know wat amp i am getting that way i will know wat upgrades i will need. if i get the SAZ 2000(which looks like wat im going to get know) i was thinking big three, atleast a 220 alt, and either 2 optima yellow tops or something similiar in power. anyone know if this is enough electrical for the SAZ 2000?
  • Who's Online   0 Members, 0 Anonymous, 1440 Guests (See full list)
