Help!!! 21 inch Sub what amp should I use
Um I'm thinking this is spam because it looks like he photoshopped some really crappy speakers into the picture to make them look big considering they arn't sitting in anything
your retarded-
as for OP are you using one or 2 subs if only using one sub its going to be hard to find a powerful amp that puts out the power at 4 ohms now if your using both subs you can wire them down to 2 ohms which you'd be good going with a solid 3k amp at 2ohms and with your budget an audiopipe 3k would be your best bet
R.I.P!
(Nov-29-2009)
92 explorer
current build
^I guess you missed where he says
What kind of amp should I use for one
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
your retarded-
The Box is going to be way too big. I can only fit one in the bed of my Truck.
Whats better the audiopipe 3k?? Or a Hifonics Colossus??
For one sub?
Current set up
Subs: (4) B&C 6's
Amp: (1) Clarion 4 Channel 640watt
Headunit: JVC KD-R800
Electrical:Stock
Box: Custom built out of 1'' Russian Birch
Wire: 4 gauge wire
Next Set Up (Adding to what I have)
Subs: (2) Celestion Vintage 30, (1) 21'' B&C
Amp: So far Legacy Predator 4000 watt. (Looking for a colossus)
Wire: 1 Gauge
Electrical: (4) Gel Batteries, alt out of a Ambulance
Box: Designed not built yet
Welcome to Idiotville, population: you.
OP, you're better off running a dual monoblock as mentioned or a pair of smaller amps like the Sundown SAZ-1500D - this way the amps will see 2 ohms each and make more power. Running a big-ass amp at 4 ohms is kinda stupid.
Stetsom might be a good option here... especially if you got one or 2 of the '2 ohm' option amps
10.x volts fo' life!
Thank you Everyone for your help.
Current set up
Subs: (4) B&C 6's
Electrical:Stock
Wire: 4 gauge wire
Wire: 1 Gauge
  • Who's Online   1 Member, 0 Anonymous, 976 Guests (See full list)
