Ludachris5150 Posted February 19, 2010 Report Share Posted February 19, 2010 My H/U only puts out 2v. Figured this could help so I bought one. Im tryna set it to about 5V. Got the cover off and everything. But how do I check what voltage its at? I put a DMM on the outside of the rca plug and it stayd at 0. Put the prongs on the inside and the numbers went crazy! What am I doing wrong? Rebuild in progress... Link to comment Share on other sites More sharing options...
abervintageman42 Posted February 19, 2010 Report Share Posted February 19, 2010 My H/U only puts out 2v. Figured this could help so I bought one. Im tryna set it to about 5V. Got the cover off and everything. But how do I check what voltage its at? I put a DMM on the outside of the rca plug and it stayd at 0. Put the prongs on the inside and the numbers went crazy! What am I doing wrong? im wondering the exact same thing, i did the same thign w/ the rca and DMM and it went crazy, i got the same line driver too Link to comment Share on other sites More sharing options...
Ludachris5150 Posted February 22, 2010 Author Report Share Posted February 22, 2010 TTT. What do I gotta have it installd with the rca inputs connected before I can get a real reading from the TLD22? I had it hookd up to a spare battery that I had layn around. Im lost??? Rebuild in progress... Link to comment Share on other sites More sharing options...
abervintageman42 Posted February 22, 2010 Report Share Posted February 22, 2010 TTT. What do I gotta have it installd with the rca inputs connected before I can get a real reading from the TLD22? I had it hookd up to a spare battery that I had layn around. Im lost??? all you need is power ground and remote turn on, then plug the rcas from the back of your HU into the input and run RCAs from the output to your amps input and then use the 2 screws underneath the cover to adjust it Link to comment Share on other sites More sharing options...
01 S-10 Posted February 22, 2010 Report Share Posted February 22, 2010 I know one part of the rca is positive and one is negative. Try putting one lead on the center pin and the other lead on the outside. (the rca comming out of the line driver going to the amp) TDH FTW !!! Link to comment Share on other sites More sharing options...
abervintageman42 Posted February 22, 2010 Report Share Posted February 22, 2010 I know one part of the rca is positive and one is negative. Try putting one lead on the center pin and the other lead on the outside. (the rca comming out of the line driver going to the amp) i tried this and still got a wayyyyyy off reaading of some negative number, i know a line driver doesnt take away voltage Link to comment Share on other sites More sharing options...
Ludachris5150 Posted February 22, 2010 Author Report Share Posted February 22, 2010 i tried this and still got a wayyyyyy off reaading of some negative number, i know a line driver doesnt take away voltage Yea I know how to hook it up. But its freezen outside so I was tryna adjust the voltage inside. Ill pry jus put it in and see what it does when it warms up a little. If I dont like it Ill toss it. Well see Rebuild in progress... Link to comment Share on other sites More sharing options...
IH8PunkRok Posted February 22, 2010 Report Share Posted February 22, 2010 i tried this and still got a wayyyyyy off reaading of some negative number, i know a line driver doesnt take away voltage negative numbers usually mean you got it backwards switch the leads and try again -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build Link to comment Share on other sites More sharing options...
