Which way to face and what design?
9 members have voted
  1. 1. Which direction to fire subs?
    • UP
      1
    • towards trunk
      4
    • towards cabin
      4
  2. 2. Which way to fire port?
    • slot port drivers side (facing front)
      7
    • Slot port out the side (drivers side)
      2
    • F*** it, run them sealed
      0
Max dimensions are 35x16x25
I've come up with 5.7 cubes after displacements. tuned to 30hz, but not too sure on how it will work. this is my first "big boy build"
2 15" RE SE subs (D2)
2 SAE-1200D
all the proper wiring etc.
Looking for a low end monster for daily use. I have plenty of extra power on tap, so the design does not have to be efficient, but more or less control the subs getting 2x RMS
and i put the sealed option in there in case someone thinks it would work out better
Please leave feedback as well, i can take constructive criticism :)
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
sorry, 01 taurus. trunk build FTL
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
30hz is pretty low idk what others will say but id tune a bit higher.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Under Construction for 2017
bumpity, hope to cut wood in the morning
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
im assuming this setup is not going to be sealed off from the trunk (correct me if im wrong) and if thats the case then itll be best to face both the subs and port towards the trunk.
I'd say subs and port on the same face of the box, that will at least leave you the option to turn the box around easily. Then you can decide if you want it to firs against the trunk or into the cabin. If you fire it into the cabin, sealing it from the trunk will be your best bet as well.
i'm hoping to not seal it off from the trunk. i will take the box out about once a month and i think think resealing it each time will be a pain. otherwise, i would just seal it, fire forward and be done.
On a side note, i've seen trunks sealed off a few times, but i've never really seen any "clean" front firing installs. I know they exist, but do any of you have some pics for examples? and yes i have search quite a bit :)
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
damn, that does look good. i'm trying to think of a way to build a frame face so that i could basically screw the baffle to a weathersealed frame attached to the opening and then that would make the box removable. any thoughts on this?
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
  • Who's Online   0 Members, 0 Anonymous, 689 Guests (See full list)
