tiller1 Posted February 20, 2010 Report Share Posted February 20, 2010 sooo i made a new set of terminal screws for my battery becuase i only had one! and when i was screwing it in it broke clean off!!!!! flush with the top of it soo i dont know how to get it out!!!!!! wiht the screw in it! what it should look like! Quote "yes... it will play like that all day!" Link to comment Share on other sites More sharing options...
fischy fisch Posted February 20, 2010 Report Share Posted February 20, 2010 (edited) they make a tool i think its called an easy out you dill a hole with a drill in reverse and then you flip the bit over and use the other side and it backs out the screw out or you can cut a lil slit in the top of the bolt and just big enuff for a flat head screw driver and use that edit :http://homerepair.about.com/od/interiorhomerepair/ss/screw_extractor.htm Edited February 20, 2010 by fischy fisch Quote lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol. Link to comment Share on other sites More sharing options...
Hellbound Train Posted February 20, 2010 Report Share Posted February 20, 2010 http://www.asseenontvguys.com/index.asp?Pa...&ProdID=380 Great for removing any broken screws. Quote Link to comment Share on other sites More sharing options...
tiller1 Posted February 20, 2010 Author Report Share Posted February 20, 2010 they make a tool i think its called an easy out you dill a hole with a drill in reverse and then you flip the bit over and use the other side and it backs out the screw out or you can cut a lil slit in the top of the bolt and just big enuff for a flat head screw driver and use that how do i cut a slit in it??? Quote "yes... it will play like that all day!" Link to comment Share on other sites More sharing options...
n8ball2013 Posted February 20, 2010 Report Share Posted February 20, 2010 i see no good resolution coming from this at all. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Neo_frog Posted February 20, 2010 Report Share Posted February 20, 2010 Use a dremel with a bolt cutting bit to sink a small slit in it. And as said, use a screw driver to turn it out. If you torqued the shit out of it (which I'm guessing you did) then you might have to drill it out and retap it. Quote Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
tiller1 Posted February 20, 2010 Author Report Share Posted February 20, 2010 Use a dremel with a bolt cutting bit to sink a small slit in it. And as said, use a screw driver to turn it out.If you torqued the shit out of it (which I'm guessing you did) then you might have to drill it out and retap it. no the bolt wasnt even all the way in! it got a little tight but not to wear i need to hands! Quote "yes... it will play like that all day!" Link to comment Share on other sites More sharing options...
n8ball2013 Posted February 20, 2010 Report Share Posted February 20, 2010 so you cross threaded it more than likely Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Guest Scylloga Posted February 20, 2010 Report Share Posted February 20, 2010 no the bolt wasnt even all the way in! it got a little tight but not to wear i need two hands! Ummm you should never need two hands to tighten a battery bolt. If you are using two hands you risk doing exactly what you did. Quote Link to comment Share on other sites More sharing options...
fischy fisch Posted February 20, 2010 Report Share Posted February 20, 2010 how do i cut a slit in it??? like neo frog said or something like that that you can use in small places with out making a big mess of the batt Quote lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol. Link to comment Share on other sites More sharing options...
