Just a quick problem i hope you guys can solve it for me.
I have some 0 gauge fleks cable that i bought in two different colors one blue one red. Both are each 15 feet long.
My question is this, i need 18 feet from my front battery to my amp that is in my backseat and was wondering since i already used up 10 feet of the blue for my big 3 how do i, or can i, hook up both the blue and red pieces together so they can give me the 18 feet i need. I know im going to cut the blue to 3 feet but what is the most safest, highest conductivity, and cheapest way to do it?
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
I would use a anl fuse holder between the two pieces.
2001 Southern Comfort Suburban sittin on 26"s
Eclipse 6620 double din head unit (2004 dash mod)
4-AQ 3500D amps @1 ohm
8-Cadence 6.5 midbass 4- in each door.
Image Dynamics Cd 1 pro HLCD
4-runs of KnuKoncepts 1/0 power wire
4-DC AUDIO lvl 4 xl 18"s in a wall
2-MECHMAN 270 AMP alternators(2 more on the way)xs power VCM
7-Deka intimidator group 31 batts(soon to be Xs power)
2-Rockford Fosgate Prime r300.4(1 bridged on mids, 2nd on CD1 horns and rear door speakers)
1-Rockford Fosgate 360.2(operated by Palm tungsten T5)My link
add an inline fuse towards the back where you need the extra wire, it will protect the wire fused near your battery all the way to the back in case it gets shorted out, which can easily happen if the wire gets nicked, plus you will have an extra line of protection in case one fuse doesn't go.
Ebay
Ive bought from him before, the fuse holders are great, just get the fuse you want when ordering.
/////ALPINE
That 0 gauge stinger coupler sure looks good but maybe too good to be true since you guys are saying inline fuse.
I already have and inline fuse a couple inches from the battery where my 0 gauge will start to go to the back but when it hits 15 feet i still need to add that 3 feet. So if i get the inline fuse do i just connect one end with the red wire which is the long one, and the other end with the blue. See my problem is that i am also running a fused distribution block where this 0 gauge will go in and convert to two 4 gauge wires so is a fuse holder to connect the two wires really the best idea? I really like that coupler but i want to be safe first off.
id run the coupler and wrap it up really good with electrical tape to keep it from grounding out.
Thats exactly what was running through my mind using that coupler and wrapping it up with a ton of electrical tape.
But then i was thinking about the conductivity, will a coupler give me more less or the same resistance as using a plain ole inline fuse holder with a fuse?
Since the coupler uses allen screws to tighthen the wire is it getting enough contact compared to a fuse holder?
Just wondering if im overthinking it with the Stinger coupler not having good conductivity with the allen screws and just go ahead and get it and wrap it with electrical tape?
Nahh, do an ANL fuse holder, like 300A, and solder the 0 gauge terminals on the sides of Meade style, if you've seen it...plus that'll give you just a bit more protection...
  • Who's Online   0 Members, 0 Anonymous, 1328 Guests (See full list)
