For my replacement build (same size stuff I have, different amp, better subs) and future wall I'm gonna go with either Fi or Ascendant. Twisted between the two, but considering they're basically the same, I have a questions regarding both. For those of you who have managed to blow either a Fi or an Ascendant or both, how difficult is it to re-cone them?
1998 Honda CR-V
Installed:
1 x Kenwood KAC-9104D amp
2 x Kenwood KFC-W3012 12" subs
4 x Kenwood KFC-1682ie 3-way components
1 x Kenwood Excelon KDC-X493 head unit
My Honda Build
Any specific tools I'd need to pick up in order to make things easy(ier)? They're not like the Solo-X where all you have to do is unbolt a few things, pull the old cone out, drop the new one in, re-bolt, and you're done, are they?
1998 Honda CR-V
Installed:
My Honda Build
Its as easy as your solo, just a little different. All you'd have to really do is pull the rubber gasket off the basket, use a knife to carefully remove the cones edging and pull off the cone. Now i'm not sure if you have to cut off the dust cap first either, someone will have to clarify, but thats how you'd remove the cone. You'd have to use some kind of silicone or epoxy when you drop the new cone in though. I think you also have to silicone the dust cap on as well. Its easier than i'm making it out to be, but all you need are two things, a knife and some silicone/epoxy. Get black if you can too, i think you can ask scott or nick to send a small bottle of it with your recone kit if you email them for it
Actually right here sir, "How to recone a Sub", guide right on the forums. http://www.stevemeadedesigns.com/board/ind...showtopic=33737
Thank you for linking that kind sir. I shall bookmark that, yet I hope that I never have to follow it...when I get my Fi's/AA's.
1998 Honda CR-V
Installed:
My Honda Build
  • Who's Online   0 Members, 0 Anonymous, 1035 Guests (See full list)
