I was hooking up the system for the first time, I got everything done, and no boom! I got 13.8 on both sides of the fuse and 1.8 at the amp. The only thing coming to my mind is a bad ground (which is bolted on a frame piece). Any ideas.
Viper 5902, big 3, 1/0 Rockford wiring, 2 xs d3100, mechman 300a, pioneer avic-z1, 2 dc 12xls, Rockford t2500.1bdcp, Rockford t1000.4ad, Rockford t2 6.5 comps, damplifier
Build log: http://www.stevemeadedesigns.com/board/topic/102584-carbon-fusion/
edit: stupid question... lol
Edited by solo_x18
Derp.
Assuming you have a multi meter check to see if your ground is good.
Turn vehicle off, put one probe of mutimeter of current amp ground and other probe on known vehicle ground. IIRC if it rests at 0.05 or less you have a good ground. Just make sure multimeter is set to 'ohms'
Derp.
also make sure the wires not pinched
R.I.P!
(Nov-29-2009)
92 explorer
current build
I have a clean run of rockford fosgate 1/0 to the trunk, The 1/0 goes to a distribution block and breaks to 4AWG and then to the amp. I'll check the ohm's of the ground in a little bit.
Well i can assume that .9 is a bad ground. but I tried putting the ground pin on the trunk latch and was still getting a .91, trunk bolts were a little above 1.1xx.
Sand the paint and primer to bare metal too ensure quality ground.
IIRC grounding to a bolt thats already on the vehicle i.e. seat belt bolt isn't a good ground.
Edit: Is it reading .9 or .09?
Edited by solo_x18
Derp.
put the 2 dmm leads together (physically touching eachother) then minus the result you get on the meter by the resistance of your ground (in this case .91) eg: if your DMM read .4 ohms when you touched the leads together, then .9-.4=.5 ohms real resistance.
Touching the leads together results in .000
