DC Sound Lab
well.... subs are level 3 10s with level 4 coils and an extra hard spider
pulled them out of the box today and noticed this
its not torn all the way threw just like on the surface didnt notice it befor because i had the subs inverted...glad i pulled them out today thats forsure! will be getting goop in the future but from under the surround ( thanks thor for that idea! )
may get a free air vid in a day or so pretty impressive xmax for a level 3 ;)
power on the subs was roughly 1500rms ( audiopipe 3k at 2 ohm to a pair of subs)
Edited by fox_racin4
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
i love thes dc sub videos but the tearing of the surrounds has stopped me from buying them so when i seen that thor went to high roll surrounds i thought yes now i can get my level 5 12''s im high roll then he tore his new surrounds so im thinking hes overpowering them and now i see your post 1500 watts on a pair of level 3's i wont be ordering mine till this issue is resolved just hope my subs can hold out that long. dc rubber surrounds problem solved!!!
sealed up on the termlab mic on dash 4-sa12"s 2-3500d's 153.4db now testing a american bass 1100.1 no numbers yet 300amp iraggi alt and kinetik batts.
thor only tears one sub being its closer to the port and with the power hes throwing at them there is no cone control and there over excurting/over throwing (sp) and the surround rips
its his box design more so then sub
as for the op didnt you have you box tuned super low
looking at your avatar you can clearly see the subs are wanging hard it was only time something happened
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
no it wasnt in that box they were fine after that i built a new box that was 2.6 at 33hz that it happend in
im assuming hte surround is the "limiting" factor on the excursion on teh dc subs i think if it had a little bigger one it would be fine
what i mean is make sure when the subs at full xmax make sure the surround has a little bit more left so they dont tear like they do
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
this box was at 33-35
and hte advatar is just a bunch of pics combined to make that lol but yes they do have a crap load of xmax they havent bottomed out either
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Just so y'all know the audiopipe 3k is rated 3k at 2 ohms not 1 so roughly 1500 watts each.
TEAM GROUNDPOUNDERS INC.
156.5 OUT THE TRUNK OF A 95 CADDY
W/1 SUB & 2AMPs
score done on a termlab mic in the kick
on the dash sealed was 154
i had it tuned a little lower then 3k so im gunna say they were eaching getting 1000-1200 still pretty good for a sub rated at 600rms i think if hte surround was a bit tougher it wouldnt of happend there still fully working with no problems still but i dont think il pul 1000+ to them right now the way they are lol
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
so you put 1000-1200 to a 600rms sub and are complaining about issues??
Makes sense to me.
so you are worried about a surround tearing. When they are clearly putting double the rated power to them. I have never had a problem out of mine and there are many other people that run them and dont have any problems with them. So I wouldnt count them out because of a tearing surround from over powering.
94 lincoln mark viii
h/u: kenwood kvt 614 Excelon
comps: alpine type x
amps: mtx 1501d mtx 4004
sub:2 DC lv4 12
wiring jl audio 0awg 8 awg sub
jl audio 4 awg for mid and highs amp
myspace.com/kylecm85
carstereolexington.com
