Alright this enclosure will be for 94delsol for a pair of 12's.
Specs come to:
-1.875 cubes net per sub
-38hz tuning
-33.6875 sq inches of port area per sub
A look at the design:
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Rabbeted the edges of the side panels for easier/better carpeting later..
Side panel on (just clamped it down and will add screws tomorrow, I prefer doing this with those rabbeted edges)
Cutouts..
Attaching the first port pieces to the sides of the front baffles..
(In the last few pics I realized I forgot one of the screws holding the panels together)
Team Tupperware
Center devider in
Port elbox inserts..
Primed
Painted
Paint drier
Corner insert in
Other side on
Primer
Painted
Drier
Team Tupperware
Other 45 insert in..
Other 2 45's cut..
Port walls and front baffles getting mounted..
Smaller port pieces and last 45's in..
Team Tupperware
Top went on and everything traced from the inside of the enclosure so that I can make accurate predrill holes..
Holes drilled..
Top on while I had some wire out for some reason..? I think I was just looking at it, lol
Team Tupperware
I got it all cleaned up and ready for carpet.
A better view of the port opening..
Team Tupperware
All finished up
Got the terminal holes cut..
Carpet time..
And...finished...
Mmhmm
Team Tupperware
looks pretty good, what kind of 12's ?
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
Thanks. RF P2's iirc
Team Tupperware
