okay so i got it running my 5.25 front and rear, everytime i turn up the bass on the bass control it switches off and when bass goes out or bass not turned up it works perfectly fine. i thought i wasnt having enough power but since i added the batcap 2000 it still does the same, im pretty sure my mids can handle it cause if the bass is low i can blast the mids loud. and i have a y splitter from a set of rca. meaning im running one set only could this be the problem? help me out guys! thanx
(shutting on and off) not the power the sound
Edited by Dbass
04 Acura TL
Sundown build coming soon.
caps are bad? yeah the 1- 20 fareds lol. are u familar with batcap? research first buddy. back to what i asked.. speakers are coaxial theres not much else to explain but amp specs are below
# 4-channel car amplifier
# 40 watts RMS x 4 at 4 ohms (50 watts RMS x 4 at 2 ohms)
# 100 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
# 2-, 3-, or 4-channel output
# Variable high-pass/low-pass filters (50-400 Hz, 12 dB/octave)
# Tuned Bass EQ (12 dB bass boost at 50 Hz for channels 3 & 4)
# Subsonic filter (15 Hz, 24 dB/octave for channels 3 & 4)
# Tri-way capable (Tri-Way Crossover required)
# MOSFET power supply
# CEA-2006 compliant
# STAR Topology (minimizes internal noise and prevents ground interference)
# Speaker- and preamp-level inputs
# Preamp outputs
# Gold-plated screw terminals
# Fuse rating: 15A x 2
# 10-gauge power and ground leads recommended — wiring and hardware not included with amplifier
# 11-1/4"W x 2-3/8"H x 9-9/16"D
04 Acura TL
I had this problem with my mf300. It would shut off when it was up pretty loud. I re-did my ground wire and it hasn't happened since. Might not be the cause but I would check it. I sanded down the paint and then grounded it. I do that for my sub amps but didn't for this amp for some reason.
what pass filter do you have it on? Hi , mid, low? I just comment because its easy to overlook something like that
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
