ok..heres the problem, iam bout to install my box and the problem is that my trunk leaks some water.and i really dont want to ruin the box.
soo is there a cheap way to seall the box other than resin?
5 15" american bass xd's in a wall
18 cubic ft ported boxx..
1 pa sl3400 for subs
all 0gauge
3 duralast batts
workin on the mids n highs
"Bend My Hat Back Knockin Down Pictures Off Ya Wall
big murt Comin Hard,
Beatin Hard In The Drop Top.
Old School Chevy's Color Candy Call It Lollipop"
Why not find out where the trunk leaks from and seal that? seeing as how you'll have wires in the trunk, and protecting your box wouldn't be the only thing I'd be worried about. Just a suggestion :P
I see Booty
2007 Toyota Camry
19" VMR Rims
H&R Lowering Springs.
Magnaflow Exhaust System
K&N Air Intake
6k HID Projectors & Fogs w/ Black housed headlights.
Optima Yellow Top - Front. Kinetik HC 600 - Trunk
Kenwood KVT-617
Rockford Fosgate 3sixty.2
Rockford Fosgate T2001-BD - Sub Amp
Alpine MRV F-345 - Front stage
Front Stage - A pillars - Dayton Audio 4" mids w/ Vifa Tweeters
Front Doors - Vifa - 6.5" midbass 1" Vifa Tweeters
Subwoofers - 2x 12" Image Dynamics IDMAX - 2.91 cuft ported enclosure tuned at 25hz
x2. Fix the trunk problem, and then that will solve all problems. :)
System Specs:
Alpine SWR-1542D 15" sub
Sealed Subwoofer Box
MTX mxa 6001 Class D 774watts RMS @ 2ohms
MTX Bass Knob
Pioneer 6.5's in doors
MTX Thunderdome 6x9 in rear
Stinger 1 Farad capacitor
80 amp stinger fuse
BIG 3 in 4 gauge wire
4 gauge power/ground wire
JVC MP3 CD Car Deck (KD-G320)
12 gauge Monster speaker wire to Sub
16 gauge Stinger speaker wire to doors
Stinger Gold Plated Battery Terminals
i had the same problem. i couldnt hunt down the leak. i even put myself in the trunk and let the hose spray water over my car for a good 10mins and i still didnt see anything, but it does leak. you are just gonna have to resin the outside of the box like i did. i mounted the amp to the back seat so no electrical components were in the trunk...havent had any problems yet.
i likes me some audio stuff...
thanx for the help guys..ima try to fix it, if it doesnt work ill jus resin the whole boxx
all 0gauge
3 duralast batts
