so i got a home audio amplifier and it has a sub out but its like an rca,is there a way to take my speaker wires and connect them to an rca to go into the sub out ? any suggestions
92 Black Acura Vigor (Blacura)
pioneer head unit
powerbass s-series 6 1/2 components in front
2 stock tweets up on the dash
2 stock 1 inch speakers by the front dome light
alpine spg-17c2 6/12s in the back,custom fiberglass pods for them
hifonics MX-3 sound processor/line driver
BIG 3 done
stock alt...not for long
1/0G all around
optima yellowtop up front
kinetik 2400 in the back
Powerbass XA3000d sub amp
2 MTX 9500 12s, single 4 ohm vc
(so only doing about 2200w)
8awg wire for the subs
stinger makes a piece that turns speaker wire to rca out for amplifier installation but I'm not sure if it works both ways but it is something to look into
On 4/20/2010 at 10:06 PM, 'cc_audio' said:
Guys are just like girls, once you've had 18 inches you don't go back.
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
Sub Amp- (2) PPI 5000BD.1
(2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
(2) 1.5" Bose Tweets
(1) JY 80 AH w/ new JY busses
(1) Duracell 750 up front
Apex Alternators 270
A.C. Delco 160 alternato
word thanks..does anybody know whats the difference between rca and subwoofer cable?
pioneer head unit
BIG 3 done
1/0G all around
sub out is very low power, just a signal. if you hooked it to a woofer it wouldnt do much of anything. its a signal line to drive a sub amp
Team DC
on a home audio reciever the sub out IS an rca low level output...it is meant to sent signal via rca to a POWERED sub...there is deff no way to power a subwoofer directly from this connection
1996 S-10 Blazer
Kenwood DNX-6140
(2)Kinetik HC2000
(2)US Amps MD3Dv2
US Amps MD42v2
(4)Hertz HCX-165 (front doors)
(2)Hertz HL-70 (dash)
(2)Hertz HT-25 (dash)
(2)Hertz SX-380D
nice thanks
pioneer head unit
BIG 3 done
1/0G all around
The RCA/pre-amp output on your reciever is meant to send audio signal to a separate amplifier for your sub. If you have a powered subwoofer, just plug an RCA cable into the "Sub out" and the other end goes into the input of the sub amplifier. Alot of powered subs also have speaker level inputs. To use those, plug your front left and rear speaker leads in, and run another set back out to the front speakers. Not sure if this info is what you were looking for, but I hope it helped.
'06 KIA Spectra
Big 3 Rockford Fosgate cable
MB Quart 6 1/2" components in the doors/kickpanels
MB Quart crossovers in the glovebox
Old School Ultimate US2125 amp on the Quarts
Old School Rockford Fosgate P800.2 on the sub
Cadence WB154 15" sub in a 3.5 cft 32hz slot port box
Future upgrades: New deck, alternator, battery..
The RCA/pre-amp output on your reciever is meant to send audio signal to a separate amplifier for your sub. If you have a powered subwoofer, just plug an RCA cable into the "Sub out" and the other end goes into the input of the sub amplifier. Alot of powered subs also have speaker level inputs. To use those, plug your front left and right speaker leads in, and run another set back out to the front speakers. Not sure if this info is what you were looking for, but I hope it helped.
fixed
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 956 Guests (See full list)
