scfaust Posted February 27, 2010 Report Posted February 27, 2010 i just bought a older car with a vinal dash thats all cracked up. ive looked to bye a new one or have it redone but its out right now can i just put fiberglass resin on it filer sand and paint same with center consel or how whould i go about doing it if i did any know have any videos or a how to pageive search the web got many diffrent answers thanks for the help guys http://i720.photobucket.com/albums/ww203/scfaust1/alphadamp.png
gogojjt Posted March 3, 2010 Report Posted March 3, 2010 i just bought a older car with a vinal dash thats all cracked up. ive looked to bye a new one or have it redone but its out right now can i just put fiberglass resin on it filer sand and paint same with center consel or how whould i go about doing it if i did any know have any videos or a how to pageive search the web got many diffrent answers thanks for the help guys well, you do have some options...if you wanted to add monitors or other mods to your dash it would be a good idea to go through the time and effort there is in fiberglassing your older cracked dash, depending on how bad the condition it is. it would take cutting your dash, making frames wrapping in fleece, soaking fleece in resin, adding fiberglass reinforcement and further molding. Now, if you were looking for a factory look, i would just buy a new replacement at a junkyard, etc. also, theyre are plastic repair kits out there like 4040 and 3m has one called plastic repair rigid parts which you could fill in the cracks and sand them down. also you could prob use some flex fillers and fill in the cracks add some kittyhair or bondo to get it smooth. once you get it smooth you can primer and paint, or add factory like texture spray. the only other option would be to get it covered by an upholstery shop. as in how to's, check youtube for fiberglassing in general and you can see different methods etc. before you did a big project on your own, i would suggest do a practice on something smaller like a kickpanel or tweeter pod, etc. caraudiohelp.com i believe offers some videos on fiberglassing, im sure there's others out there. good luck, james
Saltine Posted March 4, 2010 Report Posted March 4, 2010 that was the biggest load if mis-information and speaking out of the ass i have ever heard. sand the cracks smooth, fill the cracks with resin, get some fiberglass cloth and resin it over the whole dash pad. sand it smooth, ad light filler were needed and keep sanding til its smooth, use a sanding block. finally prime and paint. anything else will crack when it gets too hot or too cold. do what i said and yours can look like this
c_stud Posted March 4, 2010 Report Posted March 4, 2010 it was a noob whatcha expect from them 1998 Nissan 200sx NOW: Dex-p98r head Planet Audio 300.4 mids and highs Planet Audio/Pioneer tweeters/crossovers Skar SK1500.1 3 SKAR Vvx15 dual 4 wired at .63
Saltine Posted March 4, 2010 Report Posted March 4, 2010 the dash is glassed, the texture is no longer there and painted to match my cars exterior....as far as the noobs thing if you dont know just be a dont know.
gogojjt Posted March 6, 2010 Report Posted March 6, 2010 that was the biggest load if mis-information and speaking out of the ass i have ever heard. sand the cracks smooth, fill the cracks with resin, get some fiberglass cloth and resin it over the whole dash pad. sand it smooth, ad light filler were needed and keep sanding til its smooth, use a sanding block. finally prime and paint. anything else will crack when it gets too hot or too cold. do what i said and yours can look like this first off, i would like to say your piece looks really nice, great job!!! and as for the misinformation, i dont believe that it was talking out my ass...he was not very descriptive on his ultimate goals, i was just giving him some ideas on techniques and was letting him know that it takes a lot of work to get good results; example your dash....and as your advice to him is pretty much exactly how i would do it to get the results like you got. now if he was just trying to fix his dash to get it like factory, i would use plastic repair after sanding the cracks smooth, filling with the plastic repair, and more sanding till smooth and texture spray to match the factory like look. so dont knock me cause it says newbie to the forum, doesnt mean im a newbie.
Joeskey Posted March 14, 2010 Report Posted March 14, 2010 Yea i would say go with saltine's way, It can be a real pain in the ass to try n fix cracked dashes and make them look factory, hell its almost cheaper just to buy a new dash at the local junkyard, besides fiberglassin like the way saltine did always looks hot! "never drive faster then your guardian angel flies... good think my guardian angel drives a twin turbo ed beast" "its time has come for those who are different to stand united"
