Crump Posted March 8, 2010 Report Posted March 8, 2010 You need a torch, 60/40 rosin core colder, and a clamp/pliers to keep the wire in place. Just heat the back of the terminal for 15-25 seconds then just push the solder into the other side of the ring (where wire is), and just keep doing that, the wire should pull the solder down into the wire, if it doesnt just heat the ring a little lower cuz the solder goes where the heat is. Then let it cool for a minute, then what i do to cap it, is cut a good amount of wire wrap it a small tight ball and put that on top then just heat it and it usually caps it pretty good. Maybe this isnt the best way but it works for me. Pm me if you got any ?s Quote Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
Sick916 Posted April 1, 2010 Report Posted April 1, 2010 frys on northgate has all that and any radioshack should Quote 1996 Camaro RS Rockford Fosgate BD1000.1 Rockford Fosgate 400a4 Old Skool 2x 12" TSW3001-D4 Pioneer Subs Pioneer deh-p980bt Yellow Top Primary Battery 1.5 Diesel Audio Cap<Its just there to impress the females with shiny things Kinetik HC800
