Well, I got a amp kit and come to realize, I don't have the tools to do the correct soldering. Is there anyone local in or around the sacramento area, that could help me out?
Pushing it to the limits. Want more power.
have you thought about trying yourself or do you not trust yourself enough if you have any scrap wire or access to some you could practice before you try with the actual wire and connections
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
just do it yourself, its pretty easy, or find a friend that knows how..
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
i got my soldering iron at my local fred meyers, its a cheap one but it gets the job done, but with an amp kit you dont have to solder anything besides the remote wire. either get some heat shrink tubing or 3m electrical tape
2010 Subaru Impreza
Pioneer AVH-P1400DVD
2 10" Rockford Fosgate Punch HX2
Audison LRx 1.1K
superglue a dildo to the center of the cone....lube it.....then have that dumbass sit on it :good:
while playing a 10hz note
haha, this reminds me of a paintball sticker i have "my balls slap at 300fps"
now I want a sticker that says "i fuck at 10hz"
i use a iron more often then i would need a torch.buts thats me. just get both and some solder. u can find cheap ones and practice its pretty easy
6 Sundown X 15s
2 Sundown NS1 V2s
C Pillar 4th order
Bagged Suburban on 24s
http://youtube.com/tlee333
just get the propane torch from home depot. the starter set will do you ok.
should be able to get it for like $29.99
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Torch
Clicky ^^^
Edited by dwright27
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
Torch
Clicky ^^^
hes gonna need both an iron(for soldering the remote wire) and a torch(if hes wanting to solder the terminals onto the power and ground wires)....personally i see no problem with a t-tap on the remote wire(if its installed correctly) being as it is such a low current application...and unless the amp kit is 0/1 gauge any set of klein style crimpers should do the trick for the terminals...i use soft copper terminals because they crimp WORLDS easier
1996 S-10 Blazer
Kenwood DNX-6140
(2)Kinetik HC2000
(2)US Amps MD3Dv2
US Amps MD42v2
(4)Hertz HCX-165 (front doors)
(2)Hertz HL-70 (dash)
(2)Hertz HT-25 (dash)
(2)Hertz SX-380D
