MAXSPL_153 Posted March 1, 2010 Report Posted March 1, 2010 was curious if anyone has had experince with the vfl 400.1 . is it any good? anyone care for the dual 4g/ power/ground? (why not 1/0) just curious on a 5000w amp. im tryin to rive 4 18's also . i like the american bass vfl's so if a couple of theese arnt what i need , any recomendations? vfl 500.1 ? thanks gyus !
lem43606 Posted March 1, 2010 Report Posted March 1, 2010 was curious if anyone has had experince with the vfl 400.1 . is it any good? anyone care for the dual 4g/ power/ground? (why not 1/0) just curious on a 5000w amp. im tryin to rive 4 18's also . i like the american bass vfl's so if a couple of theese arnt what i need , any recomendations? vfl 500.1 ? thanks gyus ! never had any experience with this amp but dual 4g will actually draw more current than a single 0/1... it will have more surface area for current to move. But i would def make sure to run 0/1 back! 2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
n8ball2013 Posted March 1, 2010 Report Posted March 1, 2010 never had any experience with this amp but dual 4g will actually draw more current than a single 0/1... it will have more surface area for current to move. But i would def make sure to run 0/1 back! paging marlo. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
97maxima Posted March 1, 2010 Report Posted March 1, 2010 All their unregulated amps are beast, run daily under 1 ohm and as low as 1/4 ohm on burps.Kinda pricey imo. There are many comparable amps in that power range for a little less money American Bass*DC Power
herbykw Posted March 1, 2010 Report Posted March 1, 2010 All their unregulated amps are beast, run daily under 1 ohm and as low as 1/4 ohm on burps.Kinda pricey imo. There are many comparable amps in that power range for a little less money I dont know about their amps, but i got a price quote for a 15" HD and it was more then a 15" AQ HDC3 or DC Lvl 4XL 06 300C 5.7 Hemi K&N CAI JVC KW-AVX640 6.1" DVD DC Audio 3.5k 6 DC Audio 8"s 6 cubes 8" aero port at 32hrtz http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834
Boon Posted March 1, 2010 Report Posted March 1, 2010 The VFL 400.1 has dual 0/1 power inputs, not 4 gauge. Don't know where you would have got that from. Solid amp. Good to 0.25 ohms on a burp but you gotta roll them unless you have a lot of electrical power behind them. Same output section as the VFL 500.1. 500.1 is more efficient at lower voltages, 400.1 is stronger at higher voltage (15.5+ or so) Make about 4kw @ 0.5 ohms @ 12 volts. 5kw @ 14.4v @ 1 ohm. 10.x volts fo' life!
MAXSPL_153 Posted March 2, 2010 Author Report Posted March 2, 2010 ok , thanks guys . for all the info . about the dual 4g power . that's what ive read on many sites sellin them . that's a relief that they are 0/1. might just go with 4 of the 500.1's if they are a little more efficient . im not tryin to spend 5k just on power to feed these monsters
