Hey guys,
I am in the process of building my first box and I think I'm gonna need a little help.
I'd like to build a ported double-baffle box like Steve did a while back but I'm having a little trouble figuring out how to get it tuned right.
Link to Steve's build.
My question is: Which calculator would you use to tune the port? I can't find one for this style of box.
I'm gonna post some pics of my build so far but I'm warning you...this is a fuckin trainwreck. :D
Looks like a goddamn coffin. LOL
For future reference:
Subwoofers: (2) 12" Rockford Fosgate Punch HX2
Details:
* dual 4-ohm voice coils
* CONsealer gasket hides mounting screws and prevents air leaks around the frame
* frequency response 26-200 Hz
* power range 150-500 watts RMS (250 watts per voice coil)
* peak power 1,000 watts
* sensitivity 88 dB SPL
* top mount depth 5-13/16"
* sealed box volume 0.8-4.0 cubic feet
* ported box volume 1.75-4.0 cubic feet
Recommended Ported Box Volume: The ported box volume range recommended by Rockford Fosgate is 1.75 cu/ft to 4.0 cu/ft. Within this range, the ideal size recommended by Rockford Fosgate is 2.0 cu/ft, so this is the enclosure recommended by Crutchfield. One 4" diameter x 10-3/4" long port, tuned at 35Hz, should be used with a 2.0 cu/ft enclosure.
Amplifier: Boss Chaos Extreme CX950
# Chaos Exxtreme Series 2-Channel Class AB Car Amplifier
# RMS Power Rating:
* 4 ohms: 300 watts x 2 chan.
# Max power output: 1000 watts x 2 chan.
# Pulse width modulated (PWM) MOSFET power supply
# Wired remote bass level control included
# LED power and protection indicators
# Tuned Bass EQ (0-18 dB bass boost)
# Input voltage sensitivity selector
# Bridgeable operation
# Speaker-level inputs
# Variable gain control
# Thermal and short circuit protection circuitry
# Soft power-on/off
# Anodized aluminum heatsink
# Chrome-plated RCA level inputs
# Chrome-plated screw terminals
# Fixed high-pass filter (200 Hz)
# Variable low-pass filter (35-160 Hz)
# Frequency response: 9-50000 Hz
# Dimensions: 11-7/8"L x 16-13/16"W x 2-5/8"H
Alright guys, Please help a brotha out. This is ridiculous.
according to my calc i got the same freq as u so yes if u want 32.9 hz ure right on the money. and if u got a table saw add sum 45 in the corners it'll help also!!
I know a lil about everything so dont call me Mr. Know it All.
