luke perez Posted March 4, 2010 Report Posted March 4, 2010 i have 2 re mt 15s that are in my 94 s-10 standard cab pick up and they are in need of some good hard power does anyone have any suggestions i have about a 1800.00 for my budget
Decaf Posted March 4, 2010 Report Posted March 4, 2010 and whats ur electrical consist of is this an spl setup, daily, competing what are ur goals if its daily ~3000w is pretty standard, but in spl people throw gobs of powa to them
luke perez Posted March 4, 2010 Author Report Posted March 4, 2010 and whats ur electrical consist of is this an spl setup, daily, competing what are ur goals if its daily ~3000w is pretty standard, but in spl people throw gobs of powa to them i would like to put 3000+ per sub and would like to compete but this is my daily but i still am using my stock alt and am using 4 d31 yellow tops in the cab annd one under the hood big three has been done w/1/0 wire. i really like this set up i will post pics soon.
Destram Posted March 4, 2010 Report Posted March 4, 2010 3000 per sub sounds pretty sexy. Check out the US Amps. See if you can get your hands on a couple AX-3200DE amps..they're rated 3000@1 ohm. I'm not sure what they run price wise, but I'm sure you could get 2 for $1800. PM Ram here..see if he has a couple of them or if he can get two for you. He can give you a price. 2006 BMW 325i My feedback: http://www.stevemeadedesigns.com/board/topic/77301-official-destram-feedback/
luke perez Posted March 4, 2010 Author Report Posted March 4, 2010 3000 per sub sounds pretty sexy. Check out the US Amps. See if you can get your hands on a couple AX-3200DE amps..they're rated 3000@1 ohm. I'm not sure what they run price wise, but I'm sure you could get 2 for $1800. PM Ram here..see if he has a couple of them or if he can get two for you. He can give you a price. great thats one maybe i can get my wife to extend my budget
uhoh_45 Posted March 4, 2010 Report Posted March 4, 2010 what coils are on the mts? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
luke perez Posted March 4, 2010 Author Report Posted March 4, 2010 what coils are on the mts? dual 1 ohm
uhoh_45 Posted March 4, 2010 Report Posted March 4, 2010 just get 2 audiopipe 3ks and run each sub at 2 ohms and use the rest of the budget on an alt and batteries or one big amp stetsom or soundigital would be something to look into R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
luke perez Posted March 4, 2010 Author Report Posted March 4, 2010 just get 2 audiopipe 3ks and run each sub at 2 ohms and use the rest of the budget on an alt and batteries or one big amp stetsom or soundigital would be something to look into yeah iwould definitly like to get more bang but i would like to save a few bucks thanks for the input .i also have 2 soundstream 6500 but i keep having problems with them.i think i will get them fixed and then sell these big guysnot to sure quite yet
