amp shuts off randomly, then turns back on after a few seconds
rumproast789
fuck, i don't know dude, why don't you go take your car apart and try to fix it, the problem could be anything, can't fix it by talking about it to your friends on the website, go check the problem out and try to find something wrong
its cold out :)
nope used welding cable pure copper.
ima try the remote wire as the culprit first, then other ones.
I think it usually happens when im slamming, just bumpin, doesnt have to be full tilt
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
so i thought it was the remote wire. Reran, nope nothing. Still shut off. Found out one of my back battery grounds and positives or were a little loose, but hardly, and my negative on my upfront battery. Tightened them all, and will see tommorow if it shuts off. A girl that I was showing it today, said the protect light came on for a second, then went completly off. Idk whats happenin.
and btw, i ran a wire from my positive to the remote terminal, it seemed to work for two songs that it has shut off before on. but it didn't when I reran it?
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
As in, it worked with the power to turn-on, but not turn-on to turn-on? If so, then Chewie is probably right about the turn-on lead being the problem...
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
I think I fixed it. The groud was just barely loose. Enough so that I could move it when i tugged it up or down it would turn a little. So I did that, and hasn't shut off yet. Im goin to give it more time, and if that fails, ill look into borrowin a headunit
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
yep, that will do it. put a little lock tight on it if it backs out again.
  • 2 years later...
rumproast789 , did that work? Because my amp is doing the EXXXACT same thing. Let me know so I don't have to try and diagnose it doing several things that aren't necessary
should probably PM him.
  • Who's Online   2 Members, 0 Anonymous, 710 Guests (See full list)
