would it be better to ground amps to the chassis of a vehicle, or to the negative terminal of the extra batteries??? how do you guys have it on your own rides???? :-[
Nobody makes me bleed my own blood, NOBODY!!!
directly back to battery is BEST, but u can chassis ground it if u like.
thanks bro, but does it matter?? what is the advantage of grounding directly to the battery?? (just wondering)
just do both....
ok, but what happens if your amp has only one ground terminal??? i can't ground it to the chassis and the extra battery... it's either one or the other
lol well the best ground is on the batt terminal bc its resistance is something like .00001 ohms (dont memmer the amount of 0s but its more then 2). since this is usually alot lower then the chassis of the vehicle its "better" but you also have to consider the resistance of the wire and the overall length of the path to the batt neg. so depending on what your doign the chassis may end up with a lower resistance level (but it really depends on the car you have and the material the frame is made from, and if its a unibody type thing (bad for ground) so overall both is the best bet and its pretty much nessicary on high end systems. so if your really anal about this then test your frame ground and see what it shows (you meter will need to go below 0 ohms to be effective)
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
how do i test the resistance of my chasis??? where do i put the positive and negative probes??? thanks...
  • Who's Online   0 Members, 0 Anonymous, 801 Guests (See full list)
