HOW TO DO THE 3 BIG UPGRADE
Question, I own a new Nissan 2009, and I do not want to remove the factory wiring (the 8g) due to my warranty. I was told that I can just do my big 3 1/0g right over my factory wiring? Is this correct or do I have to remove the factory wiring then replace with the new 1/0g wire to get a correct 3 big upgrade? Also, although I'm running 1/0g wiring that can take up to a 300amp fuses, I choose to go with a 150amp fuse because I'm still running my stock alt at the moment that only provides 80amps at idle and 110 @ 1200 RPMs... I should be fine with this 150amp fuse or should I step it up and go with a 200/250?
HU: Kenwood KDC-MP745U.
Sub: AQ HDC 15
Amp: Hifonics BXi 1610D for sub, ZXi 6410 for mids highs
Speakers: 6.5 premium MB Quarts components,6.5 MB Quart premium coaxial back doors
Wiring: KLMX Kable 1/0g for Big 3.Double up 4g from battery to trunk...for now.
Big 3: YUP!
Battery: Shuriken SK-BT35 to the trunk.
Randoms: Flush mounted Stinger blue digital voltmeter. Flush mounted Memphis 7band EQ- 16-EQ50. phoenix gold 2 channel line driver.
Victor, Ill see you tomorrow and talk about this.
Over factory wiring, and 150amp is cherry
See you monday morning mang
Yes just do the Big 3 over the stock wiring electricity takes the path of least resistance, and your fine with that fuse.
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
I use 300 amp fuse for 1/0 guage..
Hey man, thanks for bustin out that O-scope... I don't know why people make a huge deal over having there amps O-scope for, personally you did just as good of a job by ear as that tool did. Either way thanks for going out of your way to hook it up, sounds dope.
Sub: AQ HDC 15
Big 3: YUP!
Yeah thanks for the feedback thats what I did, just wanted to make sure I wasn't doing the lazy man setup!
Sub: AQ HDC 15
Big 3: YUP!
  • Who's Online   0 Members, 0 Anonymous, 829 Guests (See full list)
