it will still play because u have contact through the rca inside the eq but u will not be able to eq it it sounds like u might just have a bad set of rca's i messed with mine for 2 weeks before i figured it out
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
ima just send it back for a return if the seller allows it and have him send me another
i got this one:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=370334673059&ssPageName=ADME:X:RTQ:MOTORS:1123
he should accept the return cause if im stuck with this POS i file PP claim :)
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
same 1 i got my problems cleared up when i got a new 1 hope it works for ui would try the new rca's first
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
ya ima just get it sent back
and for some reason now my lights arent automatic
Team Sundown Audio
There is a grounding issue somewhere for sure. It could be internally in the EQ or RCAs (or a thousand different ways). Bypass the EQ and make sure it isn't your HU or RCAs. Once you know they work, then you can figure out how the EQ is causing a grounding issue.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
the HU works fine and its not the rcas.. i took some from my theatre set up to try and they still did it so its the EQ
Team Sundown Audio
Now you just have to figure out if the EQ is bad or the ground is bad. Are the EQ and HU grounded to the same spot?
F150:
Stock :(
Processor: DSR1
yes, and i even switched them and tried tons of different places.. at least a dozen
Team Sundown Audio
Then I would say bad EQ, even if you have already come to that conclusion! :)
F150:
Stock :(
Processor: DSR1
  • Who's Online   0 Members, 0 Anonymous, 750 Guests (See full list)
