Can stock electrical handle 1500 watts rms
1400w / 12.8v = 109.375A on a 90A alt...
And your point is?
The amplifier will not pull 1400w 100% of the time so any time it does not, the excess charging capacity goes to the battery(ies) to replace what the alternator couldnt keep up with before. Also not all "90 amp" alternators are 90 amps.. could be anywhere from 90-100 probably as I assume there are ratings the alternators must meet to be advertised as rated.
Hammerdown... 1%
And your point is?
maybe not but the potential to overdraw you alt is there, no? its not about charging batteries with extra its about trying to take whats not there.
if thats the case would my 90A bosch alt + 1 farad cap handle a us md2d @ 1500w @1ohm without frying anything?
im no guru just a bass lover with enough knowhow to be dangerous...
Peep my tunes...
'99 Audi A4 Q 1.8t
Knu 1/0 Big 3
Kenwood Excelon KDC-X891 HU
US Amps Merlin MD2D 2ohm @ 1000w RMS
1x RE SX10D4 in custom ported 1" MDF box 1.25cf @ 34hz
4x Audiobahn 90w RMS 4" 2-ways
2x Kenwood Excelon 110w RMS 6x9 3-ways
2x Stock Bose high door tweets
I 'overdraw' my alt by ~1000A on a regular basis... as long as you have enough batteries behind it you'll be fine. And in the case of a 1500w system, 1 decent battery is plenty.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 1065 Guests (See full list)
