mazda 6, 158.0@30hz 4 18" subwoofers. update pics page 55,56,58,59
dude! nice build!!! i love it i need a towel and bucket!
this is some 5 star work! :D good job bro!
got the same car and similar build but with 2 15 SMDs and 2 SAZ 3500s and what alt do you have cuz i got the 08 mazda 6 and i wanna upgrade too ill be running 2 runs of 4/0 to my Xs batts and all
2-15 SP4s TL Scores
154.4 @ 40hz in Kick Outlaw
154.1@ 38hz in kick Outlaw
152.3 @ 39hz Sealed on dash
150.0 @ 35hz Outlaw
149.4 @ 34hz Outlaw
150.1 Head Rest
TEAM Fi Audio
TEAM SUNDOWN AUDIO
TEAM XS POWER
TEAM TuTwenty
My Youtube Channel .... https://www.youtube.com/user/djtomek90
Have the stock alt! Was going to put in an iraggi, but had a bad feeling about over winding such a small alt, so nothing yet. No one is making a direct bolt on. I have a nice agm charger. When I have spent the day at a show or havnt played the system in awhile I throw the charger on and bring em up, if they need it. What direction are you firng your port? Up or forward? I am curious about that.
Very nice and clean build man :clapping:
Thank you sir!
i'm surprised your car is not in pieces yet...! awesome build! loved the fans :D
The car has been holding up pretty well. My winshield had a small rock chip that turned into a full blown crack. I had the window replaced and the installer did a shitty job. My car leaks air when I drive 30+ I can hear the damb wind like my window is down. Took it back and still didnt fix it. I am going to find someone who knows what they doing to re-set the window.
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
same here :) i found a 190 amp alt on maniac motors i googled it and for 290 or so a 190 for out cars :)
and subs foward and port forward box is 15.75in tall 40in wide 27in deep :)
2-15 SP4s TL Scores
150.0 @ 35hz Outlaw
149.4 @ 34hz Outlaw
150.1 Head Rest
TEAM Fi Audio
TEAM SUNDOWN AUDIO
TEAM XS POWER
TEAM TuTwenty
I think you need more port area to break into the 151+ range.
Custom make a port out of whatever you can get your hands on (glass, wood, pvc, etc), and the larger you make the exit (flare) towards the rear window the better probably too.
the other option is the space the 18's apart as far as possible (could even angle them inward a tad) and put the port in the center contoured to the mounting ring of the 18's.. there's a system thread in on here somewhere that someone did that :)
Really nice looking though :)
Hammerdown... 1%
nice work man. what kind of suspension are you running? coilovers or lowering spring?
I am using lowering springs. Eibach pro kit.
Port was 6" when I hit the 150.6 port is now 8" and hitting 150.4. I compensated for size by length and even cut some off to see if this changed things. Nothing. ;0( new subs should help!... maybe. I might add an 18volt system and say f it! an extra 4000 watts never hurt nobody!
  • Who's Online   0 Members, 0 Anonymous, 1766 Guests (See full list)
