well today the first adassa audio warlords have arrived in the UK.  and might i add they are beautiful pieces of work.  and i will be running 4 of them in my vehicle.
The Adassa Audio Warlord will be at DB Drag Finals and Meca Finals in a red jeep driven by Snoopdan.  im sure most of u know who that is.  so if u want a peak at the amps at finals look him up. u will see the big adassa logos on his windows.
ok enough with the talk here it is!!
                              CONGRATS TO ANDREW
He has put alot of money and effort into gettin Adassa up off the ground with a "little" help by me but i do the easy stuff.  heh.
yes im running 4  TREO SSX18's
FEATURES
Digital Class D Linkable Mono Block Amplifier
Daisy-Chain Through Output RCA
Dual MOS-FET PWM Power Supplies
Stable into 1 ohm and 2 ohm Parallel Amplifier Connection Availability
24 dB Low Pass (LPF) Crossover Variable
18 dB Bass Boost Equalization Control Variable
180 degree Variable Adjustable Phase Shift
24 dB Subsonic Filter Variable
****Selectable Switch for MASTER and SLAVE operation****
Speaker Short, Over Current, Thermal, and DC Portection Circuit
RCA Line Input and Line Out
Heavy Duty Cooper Layer Double Sided EPOXY PCB
2 x 0 Gauge (AWG) Battery Input Connectors
100% QC Testing and Warm UP
Efficiency: 86% at 4 ohm, 100hz
Operating Voltage: DC 10V ~ 18V Power Input
Damping Factor: Better 350 into 1 ohm
Wired Remote Bass Gain Controller with 5 Meter Flat Cable: Optional
SPECIFICATIONS
RATED POWER OUTPUT
RMS Power 1 ohm (12.0V)-------------------------------- 3400W x 1CH
RMS Power 1 ohm (14.0V)-------------------------------- 5000W x 1CH
RMS Power 1 ohm (16.0V)-------------------------------- 5900W x 1CH
RMS Power 1 ohm (18.0V)-------------------------------- 7500W x 1CH
2 SAME UNITS PARALLEL LINKED
RMS Power 2 ohm (14.0V)-------------------------------- 9900W x 1CH
RMS Power 2 ohm (16.0V)-------------------------------- 11800W x 1CH
RMS Power 2 ohm (18.4V)-------------------------------- 14900W x 1CH
Signal to Noise Ratio ---------------------------- >100dB
Low pass frequency crossover ---------------------- 35Hz~300Hz
Subsonic filter ------------------------ 10Hz~60Hz
Bass boost @ 45Hz------------------------------ 0~18dB
Phase Shift Control -------------------------------- 0~180 degree
Frequency Response ------------------------------ 10Hz~350Hz (+/- 1dB)
T.H.D. @ 4ohm ------------------------------ <1.0%
Efficiency @ 4ohm -------------------------------- 86%
Fuse rating ------------------------------ 250A x 2 (External Type Fuse)
Input Sensitivity ------------------------------- 200mV to 6V (+/- 5%)
Dimensions ----------------------------- 270(W) x 65(H) x 620(L) mm
The above specification shall be modified by manufacturer for improvement without prior notice
Guest 90accordman
How much do those cost and where are they available?
theres a post with a little more information on westcoastSPL.com
or go here www.adassaaudio.co.uk
I asked the same question, and was told depends on if your a competitor or not.  then never got an answer.
that amp looks very nice man. i'd definitely run two runs of 1/0 gauge + and - and get a badass alternator for that junt. nothing like running multiple subs with only one amp.  i guarantee that amp is over $5000
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 734 Guests (See full list)
