bruneian Posted March 14, 2010 Author Report Share Posted March 14, 2010 and the port size is up to you,it depends on what frequency you want the box tuned to. now port tunning and the cross over frequency that you tune the sub to are two seperate things,so don't get that part mixed up. the first thing you want to know is how many cubic feet of air space both subs will require and how many cubes you have in your car or wherever the box is going.it's at this point you can decide how you want to build your box. i want to make vented enclosure port...if my box is 8 cubic feet..do i have to add extra space for my port?or 8 cubic feet is already enough? Quote Link to comment Share on other sites More sharing options...
Sanitarium Posted March 14, 2010 Report Share Posted March 14, 2010 totally uncalled for. you're right. I apologize. this guy just needs a lot of help is all. Quote Link to comment Share on other sites More sharing options...
Torres Posted March 14, 2010 Report Share Posted March 14, 2010 if you have 8 cubes of total space, then everything will get deducted from that. such as wood, port, sub, and bracing displacement. 8 cubes is GROSS volume, while the volume you get after subtracting all displacements is NET volume. so if you want a net volume of 8 cubes, then the port volume will be extra volume added to the overall box Quote Link to comment Share on other sites More sharing options...
gofastcrazy Posted March 14, 2010 Report Share Posted March 14, 2010 (edited) you have to subtract the thickness of the board you are building with( this includes the port cause your building it out of the same mdf) thats port L X W X H devided by 1728 of your port. that will be the volume of air inside your box that the port is taking up.your speaker will take up some too but the manufacturer will give you thise numbers.( this part is not really that important unless your competeing for SPL or DB DRAG. Edited March 14, 2010 by gofastcrazy Quote Link to comment Share on other sites More sharing options...
gofastcrazy Posted March 14, 2010 Report Share Posted March 14, 2010 remember your final calculation ( cubic air space )will be the inside of the box( the measurements you get ) not the outside to outside distance cause you subtracted the thickness of the wood. Quote Link to comment Share on other sites More sharing options...
bruneian Posted March 14, 2010 Author Report Share Posted March 14, 2010 if you have 8 cubes of total space, then everything will get deducted from that. such as wood, port, sub, and bracing displacement. 8 cubes is GROSS volume, while the volume you get after subtracting all displacements is NET volume. so if you want a net volume of 8 cubes, then the port volume will be extra volume added to the overall box ive done my box length...what is the good tuning for my box?im using double t1...ive been making 8 cubic feet box by its volume...what is the good tuning for my woofer ? Quote Link to comment Share on other sites More sharing options...
bigmescan Posted March 15, 2010 Report Share Posted March 15, 2010 hey man not trying to give you shit but if you really dont understand this have someone build a box for you. reason im saying this is because i just built a box like 3 hrs ago and i put the port in a wrong placeand its doesnt look like an L shape. (dontask) and i have some knowledge and my father is a carpenter and when he looked at the box he said hey son the opening at the back of the box doesnt look like your other box does. all im saying is. if you are willing to try just be patient and by like 100 sheets of MDF. j/k because you will screw up. Quote SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74 Link to comment Share on other sites More sharing options...
