TyC2010 Posted March 16, 2010 Report Posted March 16, 2010 how do i connect two kicker zx2500.1's so that each one pushes a Fi BTL 18". any imput on this let me know guys thanks....
cvxsmitty58 Posted March 17, 2010 Report Posted March 17, 2010 First you need to make sure that the btl is dual 2 ohm since those amps are only stable at 2ohms and i dont know if they are linkable but you'll have to gain match them perfectly.
TyC2010 Posted March 17, 2010 Author Report Posted March 17, 2010 First you need to make sure that the btl is dual 2 ohm since those amps are only stable at 2ohms and i dont know if they are linkable but you'll have to gain match them perfectly. Alright
rc.btl Posted March 17, 2010 Report Posted March 17, 2010 ur gonna want a dual 1 ohm so u can run it at 2ohms each one the amps. 2004 Grand Prix HU: Alpine 9886 for sale Sub Amp:AQ2200d (possbly 2) Enclosure:BCP Designs. Best for the Money Electrical:1 Stinger SPV70 battery Subs:2 15 D2 AQ HDC coppers Wiring:0gauge power SoundQuest Wiring:0gauge ground Kicker 141.8 @ 28hz tl legal on the dash. 142.6 @ 33hz tl legal on the dash.
Boon Posted March 17, 2010 Report Posted March 17, 2010 Im a little confused... are we talking about 2 2500's pushing 2 BTLs (in which case you want D1's) or 2 2500's pushing 1 BTL (in which case you want a D2) Either way... if you have to ask this question, should you really be running 5kw? 10.x volts fo' life!
TeejayBee Posted March 17, 2010 Report Posted March 17, 2010 If your putting two of these amps on one sub get a D2 and one amp per coil but if your getting two subs Get D1 and wire them up to D2 then you got it
TyC2010 Posted March 17, 2010 Author Report Posted March 17, 2010 Im a little confused... are we talking about 2 2500's pushing 2 BTLs (in which case you want D1's) or 2 2500's pushing 1 BTL (in which case you want a D2) Either way... if you have to ask this question, should you really be running 5kw? 2 2500's pushing 2 btls. And my question was how to link the Amps together. Iv never ran 2 amps before. I'm 18 and just wanted some advise from the experts.
dwright27 Posted March 17, 2010 Report Posted March 17, 2010 youll want to gain match the amps first off. take a DDM or Oscope and hook them up to your speaker outs on the amp. put the oscope/DMM on to the AC Voltage setting. preferably you do this with an oscope so you know when you are clipping. and set the gain on each amp so the voltage matches. make sure youre setting of the crossovers etc on both amps are the same as well. also youll want Dual 1 ohm coils. 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
