cvxsmitty58 Posted March 20, 2010 Report Posted March 20, 2010 So the other day i noticed that my front doors went out. about a month ago i put the 6x9 kappas in and they worked fine, now nothing. Oh and there seems to be a ton more ground noise coming out of the other speakers. If anyone has any input it would be greatly appreciated.
Ray Posted March 20, 2010 Report Posted March 20, 2010 2 common problems with that truck 1st, factory infinity amp fails. 2nd, broken wires in the door boots. Ive seen both more times than i can count 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Freshman6969 Posted March 21, 2010 Report Posted March 21, 2010 i have an 02 GC, i put subs in about 3 months ago, cranked it up, after a few weeks my left front door went out, which causes the tweets to go out( mind you i just put brand new tweets in, btw can anyone explain how the fuck that works? how the speaker is hooked to the tweeters and what i would have to do in order to totaly replace the speakers and amp?) anyway, now my left front door is out, my driver side door goes in and out when i turn it to a cirten point, and only my rear spekaaers totaly work, infinity SUCKS, just trash the amp run new wires and post pics , if you do go around with replacing the amp and running wires and such itd be very helpfull Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
Freshman6969 Posted March 29, 2010 Report Posted March 29, 2010 sorry to bump an old thread but did you rewire your new speakers with a new amp by anychance? im getting my amp+speakers this week so figured id ask Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
cvxsmitty58 Posted March 29, 2010 Author Report Posted March 29, 2010 no not yet....im still workin on gettin the new system in.....i plan on going with a 4 channel amp tho.....prolly stick with aq. Will be atleast a couple months out.
Freshman6969 Posted March 30, 2010 Report Posted March 30, 2010 sounds good dude, well im going to attempt a build log for running all the wire and installation and such, since i cant find worth shit on how to rewire my jeep -.- Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
cvxsmitty58 Posted March 30, 2010 Author Report Posted March 30, 2010 check this out, it shows a complete jl upgrade http://www.wjjeeps.com/jlaudio.htm .......wjjeeps.com is great for finding out how to take stuff apart too
