psx2p Posted March 20, 2010 Report Posted March 20, 2010 So i followed this set of instructions after thinking i was doing something wrong and still no luck in measuring the Voltage from my amp to the subs. i am trying to figure out how many Watts im pushing to the woofers. i know what people thought it would be but i want some numbers to back it up, when i connect the - and + leads upto the terminals and play the 40hz track i get the same readout as i do when playing normal music which is .012 to check if the meter was functioning i flipped it over to DC and checked the power input and sure enough it was registering perfectly, what am i doing wrong? Another thing, due to the VERY shity manual of this craptastic Performance teknique amp is there anyway to tell if its actually at 2ohm when im only running 2CHs from it? i know my subs are wired @ 4ohm but i dont think the amp is at 2ohms because theirs never a heat issue.. i could be wrong, below are ALL the details provided for this amp ICBM-8914 Channel Bridgeable Power Amplifier * 24dB Crossover * Variable Low Pass Filter (30Hz~500Hz) * Variable High Pass Filter (50Hz~1KHz) * Variable Bass Boost (0 ~ 18dB) * Variable Subsonic Filter (10Hz~100Hz) * Wired Bass Remote Control * RCA Line Output * Double Sided PCB * High/Low Level Input * Two Way Protection * Tri-Mode Speaker Connection Stable * 2 Ohm Stable Stereo * Soft Delayed Power On * 0.05% THD 800W max 01 GMC Sonoma 4x4 RF T1500.1bd DC LVL 4 12"
MikeyF Posted March 20, 2010 Report Posted March 20, 2010 So i followed this set of instructions after thinking i was doing something wrong and still no luck in measuring the Voltage from my amp to the subs. i am trying to figure out how many Watts im pushing to the woofers. i know what people thought it would be but i want some numbers to back it up, when i connect the - and + leads upto the terminals and play the 40hz track i get the same readout as i do when playing normal music which is .012 to check if the meter was functioning i flipped it over to DC and checked the power input and sure enough it was registering perfectly, what am i doing wrong? Another thing, due to the VERY shity manual of this craptastic Performance teknique amp is there anyway to tell if its actually at 2ohm when im only running 2CHs from it? i know my subs are wired @ 4ohm but i dont think the amp is at 2ohms because theirs never a heat issue.. i could be wrong, below are ALL the details provided for this amp Read up on this right here, Amp Output. Your meter should be on AC voltage. What kind of meter do you have? Is the hold button on, or off? 12" DC LVL 4 Sundown 1200D PG RSDs PPI PC2100 Alpine 9886
kandiman71874 Posted March 20, 2010 Report Posted March 20, 2010 Read up on this right here, Amp Output. Your meter should be on AC voltage. What kind of meter do you have? Is the hold button on, or off? His meter type doesnt mean shit if he isnt using an amp clamp to measure the a/c amperage along with the voltage.. voltage x amperage= wattage remember? Daily Driver 1999 Kia Sephia Kenwood DNX-893s Audison Bit One Processor 2 Dat 4.125's Sundown Audio SCV-6k Hertz hsk-165xl's Mids running active Focal V30 Series Tweeters running active Sundown Sa-8 v1's in the doors 2 Sundown Zv5 12's Lots of Hushmat Big 3+ and 3 + & 3- runs of Trystar 2/0 2 Dc Power Engineering 320 HP Alts 2017 Comp Vehicle 2006 Toyota 4 Runner Kenwood Excelon DNX-893s Audison Bit One HD DSP 4 Sundown Sa 6.5v2 Component Sets Focal Access 6.5 2 ways Sundown Audio Sax-50.4 Sundown Audio Sax-100.4 2 Dc Power 370xp Northstar agm27f Northstar agm65 2 Northstar asmagm 480's 2 Dual 1 Sundown Nightshade v3 12's 2 Sundown SCV-7500's All SMD Fuse Holders Shitload Of Sundown 1/0 120 sq ft Second Skin Damp Pro No, Its Not A Burp Truck!!!! 2016 Season 3rd place in Xtreme 1 At Finals 2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations) 2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL David said: audio is a lifestyle, not a hobby newls1 I cant read a tape to save my life... 1/2's are ok, but other marks confuse me kingsuv only men who cant read a tape, take it in the ass kingsuv you sir, get a pink hard hat on jobsites
psx2p Posted March 20, 2010 Author Report Posted March 20, 2010 hmm im only using my DMM and its a fluke meter, 01 GMC Sonoma 4x4 RF T1500.1bd DC LVL 4 12"
