umm depends on the voice coils you get, and if you wire them in series or in parallel.
Dual 2 would get you either 4 ohms (series) or 1 ohm. (series
Dual 1 would get you either 2 ohms (series) or .5 ohm. (series)
(you can't run a .5 ohm load that on that amp - not many other amps either, for that matter).
Do you understand how ohm load affects power output of an amp?
a Fi BL is rated 1000w RMS, doesn't matter the voice coil setup.
that amp does 650 RMS at 4 ohms, 1300 RMS at 2 ohms, and 2000 RMS at 1 ohm....
so you see where it's a bit overkill.
unless you're running more than one Fi BL, of course....
is there something i'm not seeing here? i mean i know Fi's are some hardcore woofers but he could run that shit at 2x rated RMS with that amp... he could save a couple bucks and get something that does like 1200 RMS at 1 ohm and make it superclean power.
or am i wrong?
yeah .. actually fully loaded... 2k (clean) would be legit.
but by the way he talks i'm thinkin he maybe doesn't know a whole lot ..
so if he orders them stock and drops 2k on em and jacks the gain, with stock electrical....
kaboom?
kaboom?
Yeah def if it wasnt fully loaded on 2000rms but he probably wont get that with a stock electrical. If its fully loaded or even with just the flatwind coil option i bet he would be good with that amp. I got mine on the Sundown saz 1500d at 1ohm and it wants more. And we all know the 1500 puts out more then its rated.
6 Sundown X 15s
2 Sundown NS1 V2s
C Pillar 4th order
Bagged Suburban on 24s
http://youtube.com/tlee333
  • Who's Online   0 Members, 0 Anonymous, 1523 Guests (See full list)
