billybunter Posted March 21, 2010 Report Posted March 21, 2010 Hi people, can someone tell me what sort of port size i need for 2 15" sub with an enclosure of 5 cu ft. im not too sure how big the port hole should be so if someone can help me that would be great.
R_Mac_1 Posted March 21, 2010 Report Posted March 21, 2010 The usual recommendation is 12-16 sq in of port per cube of box volume. So 60-80 sq in of port in your case. 2002 Pontiac Bonneville SSEi Pioneer DEH-P6000UB Alpine SPX-17REF 6.5" components (active) Sundown SAX-50.4 Sundown z15 (3 cubes @ 35 hz) Sundown SAX-1200D 2006 Buick Rainier CXL AWD V8 Stock Bose system 12" Alpine Type E in aeroported box Profile AP1000M
pRoFsWiRlY Posted March 21, 2010 Report Posted March 21, 2010 The usual recommendation is 12-16 sq in of port per cube of box volume. So 60-80 sq in of port in your case. Does this just refer to the opening of the port itself? Where does length of the port come into play, and therefore adding more overall size to the box to compensate for the material of the port taking up room? Ride - 2006 Scion xB Equipment: H.U. - Kenwood KDC-X793 Amps - Memphis 16-MC2.100 Memphis 16-MC1.1100 Front Stage - Memphis 15-MCC6 6.5 Components with silk dome tweets Subs - Memphis 15-M310D4 10" Sub (x2) Custom box 3.02 ft3 after displacement, tuned to 37 hz Big 3 Second Skin Damplifier Coming soon: Kinetik HC1400 H.O. Alt AudioControl three.1
k3n12ock Posted March 21, 2010 Report Posted March 21, 2010 To be honest, 5 cubes for (2) 15s is sort of small don't you think? I would think at LEAST 3 cubes each. Anyway, what kind of subs on what amp in what type of vehicle? 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
billybunter Posted March 21, 2010 Author Report Posted March 21, 2010 To be honest, 5 cubes for (2) 15s is sort of small don't you think? I would think at LEAST 3 cubes each. Anyway, what kind of subs on what amp in what type of vehicle? They are two fli 15" 400RMS I got told for one 15" fli sub a 2.5 cuft is required (this was fli themselfs) so I just double the figure. They will be ran on a kenwood KENWOOD KAC 9104D 1 CHANNEL MONO 1800W which with the way im hooking them up will give out 900RMS between them, or so I believe. They will be going in to a focus hatch back. I also got told I am able to use a ported sub box with them. Just quite confused to what height length and width the port needs to be.
R_Mac_1 Posted March 21, 2010 Report Posted March 21, 2010 Does this just refer to the opening of the port itself? Where does length of the port come into play, and therefore adding more overall size to the box to compensate for the material of the port taking up room? Yes, that refers to the surface area of the port opening (how big the hole is). The length of the port will determine tuning. In the subwoofer section there is a stickied thread at the top that has a box tuning calculator that will help you design your box a bit. http://www.stevemeadedesigns.com/board/topic/38791-torres-exposport-box-tuning-calculator-updated-310/ 2002 Pontiac Bonneville SSEi Pioneer DEH-P6000UB Alpine SPX-17REF 6.5" components (active) Sundown SAX-50.4 Sundown z15 (3 cubes @ 35 hz) Sundown SAX-1200D 2006 Buick Rainier CXL AWD V8 Stock Bose system 12" Alpine Type E in aeroported box Profile AP1000M
billybunter Posted March 21, 2010 Author Report Posted March 21, 2010 Yes, that refers to the surface area of the port opening (how big the hole is). The length of the port will determine tuning. In the subwoofer section there is a stickied thread at the top that has a box tuning calculator that will help you design your box a bit. http://www.stevemeadedesigns.com/board/topic/38791-torres-exposport-box-tuning-calculator-updated-310/ Yeah I used that but it confused the hell out of me! I know the size I want the box but I dont know what size I need to make the port. back of box (height one) 19" depth of box (the side of the box) 22" width of the box (looking at front) 40" height two (looking at the front of box) 6.5" this will give me the cuft needed for my subs....I just dont know how big to make the port
