hey people I was wondering which subs to go for;
FLI 15" 400 rms 1200 peak
or
JBL 15" 350 rms 1400 peak
I want something that will hit me hard and sound very good. Im in to Rap n stuff like that. I have already bought a KENWOOD KAC 9104D 1 CHANNEL MONO 1800W I thinking of runing two of which ever ones I get and just wanting some imput instead of wasting money on crap...again
need more info on the subs your considering never heard of fli what model of jbl sub is that also is that kenwood amp is 2 ohm stable I believe and that will play apart in what subs you use
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
dont get the jbl, jbl sucks balls
get the fi
first off the they are not FI they are FLY (but spelt FLI)
kenwood
# 1800W MONO bass amplifier
# Rated power (4 ohm, 20 ~ 200 Hz, 0.5% THD) @ 14,4V : 500W RMS
# Rated power (2 ohm, 100Hz, 0,9% THD) @ 14,4V : 900W RMS
# Rated power (1 ohm, 100Hz, 1,0% THD) @ 14,4V : over 900W RMS
# Maximum output power @ 14,4V : 1800W
# Aluminium Die-cast heat-sink with Aluminium dress-plate
# Power MOSFET Switching Power Supply
# 1 ohm load capability
# Gold plated RCA Line in & output
# Gold plated terminals
# Plug-type Speaker Level Input
# Dual Mono Drive
fli sub
MS power : 400 watts
Peak power : 1200 watts
Minimum input : 200 watts RMS
Sensitivity : 90dB
Frequency response : 20Hz - 1500Hz
Mounting diameter : 350mm
Mounting depth : 148mm
Voice coil : 2” aluminium 2 layer
Magnet material : Ferrite
Magnet weight : 52 Oz
Magnet size : 140mm x 25mm
Magnet rating : Y25
JBL
# 380mm (15" subwoofer)
# RMS Power Handling: 350 Watts
# Peak Power Handling: 1400 Watts
# Sensitivity: 93dB
# Impedence: 4 ohms
# Polypropelence woofer cone
# Proprietary aluminium die-cast basket
# Vented motor structure
thats all the information about them, I want a ported sub box, now i just need some decent subs. I live in the UK but im open to any suggestions to other brands of subs
Only im looking for about £100 a sub and about 450RMS each sub ( i want two 15")
well never heard of the flI but the jbl is a lowend sub in there line up will sound good don't expect it to be to loud or crazy spl wise mabe you should think about buying one better sub then saving up and buying another instead of two lowend subs just my 2cents
big 3 1/0
well out of them two which would be the loudest so to speak.
I will buy better ones this is just for now and update summer.
a sub is only as loud as the box its in. and what budget do you have?
edit: only look at rms
so two 450 rms 1000 peak would be better than 400 rms 1200 peak?
I have about £300 for subs in dollar its about 700 i think
  • Who's Online   0 Members, 0 Anonymous, 1615 Guests (See full list)
