Ok so im going to be installing a system for a friend who doesn't want an aftermarket stereo. Im going to be using a line out converter off of the rear speakers and i wanted to know would if it matter where in the speaker wire i hooked it in? It would be a ton easier to do at the rear speakers since they are exposed in the trunk, but if i need to do it close to the head unit i will. Any and all help is thanked for in advance.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
From what I've always read it's usually recommended to do it near the rear speakers, but don't quote me on that.
Good i was planning on doing it that way because i dont want to have to pull the stock radio.
I got mine hooked to the wire right at the rear speaker. Make sure to use a quality line converter, some of the cheaper ones can introduce noise and/or fluctuating voltage.
Ok. Thanks for the info.
New question. How do you hook up a LOC with a factory amp?
  • Who's Online   0 Members, 0 Anonymous, 1116 Guests (See full list)
