Toady's 2000 Grand Am Gt (New Pics On Pg.2)
looks nice so far man want to see the lambos on it and air ride will look good
Thanks man, Yeah im ready for the air ride and lambo's it gonna be nice
Quick update, a couple days ago i had a underglow tube go out on me after some years, so i ripped the old off, and in with a new set
And A Set of illegal bright in the grill (You Know How We SMD Members Roll)
Also today got 2 new sets of fuse blocks, 5 new ANL fuses, and some more parts for the system. Carpeted the amp rack today, made new grounds for the amp, ran 3 new sets of RCA's, got more to come and pictures and videos tomorrow
wheres pics? been 4 days
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
  • 1 month later...
Sorry guys for the long wait, had alot go on in this much time. To start off Db Electrical 220 turned out to be a huge doorstop which i got a refund. Went with A mechman 270 large-case (Greatest Thing Ever. Got rid of small 12 ga speaker wire going with 8ga kicker hyperflex, 3 New sets of rockford rca's. Got rid of the old box tuned to 42 hz, and went with fully custom Dual 12'' 1.93 cu ft per chamber tuned o 34 hz. I recently ripped out the subs, amp rack, fuse rack, 10 lbs of wire, speakers, etc. Going with a new layout to fix things i messed up at the beginning of the install. Went with brand new anl and maxi fuses.New tweeters in the doors (Powerbass PBX::: Extreme 3xl's. Lots of work being done, will have pcs up in following days.
Got alot done today, heres some pics
New Mechman 270 Largecase
Some wire taken out and using again
Old scosche rca's, that sucked
Much better
Messy right now
Will be 100 percent hidden
Main switch that turns off everything in the trunk, AMps , subs, led's, epicenter, etc. used in emergencies
Cap Bank (I Know I Know)
C-600
New 8 gauge speaker wire
Got another spool of Hyperflex 1/0 today
New box is being built (Got rid of the prefab), amp rack is being cleaned up, new pulleys on the way, a ton of cleaning , mounting, and installing left. More pics and vids on the way
Looks good so far!
Thanks man, i should have pics up a little later today, rewired the amp rack, new fuses put in, and got a update on the box, It's being built right now, it will be for 2 Alpine Type R 12's, 1.96cu^ft per chamber total of 3.92cu^ft tuned to 34 hz. The old prefab was tuned to 42 hz (<-- It sucked). The new box should be here june 1st, after the install videos, and pics of the almost completed install will be posted
Did some more work tonight got rid of the busted fuse block under the hood, installed a new one with kicker 200A. Also cleaned up all the wires on the driver and passenger side
