audiofreak10 Posted March 31, 2010 Report Posted March 31, 2010 Hey guys, Putting an amp in my car this weekend and figured that since I will have the car apart anyways, I should just go ahead and do the big 3 while I'm at it.Amp is rated at 1000w (600rms) and the alternator is 140a.Just wanted to make sure that when I do the big 3 that I do not cut anything,just add another wire to that post,bolt,etc right? Some people are telling me to cut off the wires that I'm not using.Thanks
keepinitloud Posted March 31, 2010 Report Posted March 31, 2010 leave the stock stuff in place just add on top of it for your big three 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
-Hobby- Posted March 31, 2010 Report Posted March 31, 2010 Dont cut or remove anything. Just add the 3 wires.
audiofreak10 Posted March 31, 2010 Author Report Posted March 31, 2010 Thanks guys,that's what I needed to know.Much appreciated. One more thing,the tutorial doesn't say anything about soldering the connection,should I? or will crimping be fine?
anubis Posted March 31, 2010 Report Posted March 31, 2010 do u have a cs144 alt? if so i got a 200 amp from a company callled EMS for bout $350 if your interested in upgrading 1998 Monte Carlo Z34 Stock HU but have replacement Stock Highs Stock Electrical BTL 18 sitting naked AP1500D
z71kris Posted March 31, 2010 Report Posted March 31, 2010 If you crimp, crimp and solder..if not just solder really good.. 03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
audiofreak10 Posted March 31, 2010 Author Report Posted March 31, 2010 If you crimp, crimp and solder..if not just solder really good.. Thanks
audiofreak10 Posted April 2, 2010 Author Report Posted April 2, 2010 Apparently my car has more than one engine to frame ground.Do I need to replace all of them or will replacing one that isn't a pain to get to going to be enough?
ktm300 Posted April 3, 2010 Report Posted April 3, 2010 You dont have to remove any of them, just add new wires to the increase the capacity. Crimp then solder you're wires, dont forget to fuse the wire going from the alt (+) to batt (+)
