will a sanding wheel on a drill clean the basket up well enough? i just need to remove the paint correct?
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
You also need to remove any left over glue or surround residue from the surround and spider landings.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
O ok yea just get the paint off then. Sanding Disk and drill should handle that no problem... Watcha workin on?
just got one did used a wire wheel on a drill then a small sanding disk to finish it up
2 DD9512s F style motor with G basket
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
I like Scotch Brite pads. Why, Because you can't fuck up or if the drill gets out of hand and you don't have to worry about accidently cutting into the basket or notching it some place it ain't supposed to be notched at. LOL
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
lol i got it cleaned up pretty god.... somehow metal shaving got into the gap tho... not sure how the basket was off the motor when i cleaned it whats the best way tog et them out?
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Probably a very lightly damp paper towl man and a lot of patience.
and a tooth pick or Q tip.
Edited by ISO
there isnt much im trying a "pick" tool with a rag wrapped around it i dont have a clue how it happend lol
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
A tip for later is to use blue painters tape to cover the area in the Pole.
