maniac's suburban sub box build
I figured i would show my box build as this is my first ported enclosure.
specs: FI Q 18 replacing old setup of 2 p3 fosgate 12's
Vehicle: 99 chevy suburban
Box: 8 cubes 138 sq in of port tuned at 34hz (James Design)
47"w 22"h 20"d
I cut all the boards first then put the main structure together
test fit of the port
clamped the baffles together and cut the inside hole first, with a jigsaw ftl.
used plenty of glue all the way around.
after cutting both baffles, time to glue both peices together.
plenty of glue and screws to complete the baffles.
i drilled offset holes across the whole front for the screws, and of course plenty of glue.
final install of the port
caulked the whole inside of the box before installing the top.
pre drilled the top before glueing and installing the final peices
completed box with 1" wood dowel installed in the center for bracing.
thats it for now, i will be making an amp rack and carpeting the box soon. let me know what you guys think.
99 suburban
20" boss motorsport wheels
big 3 installed (thanks Iraggi)
alpine 9886 deck
kenwood 11 band eq
fosgate t5002 amp running sub
kenwood ps200 amp running components
jl xr components in front doors
jl xr 6.5 in rear doors
jl in rear roof
1 FI Q 18" with bp
enclosure 8 cubes 138 sq" port 34hz
Iraggi 220 ho alt
(RF 1500bd coming soon)
looks great, whats the dimensions of the box?
47"wide 22" tall and 20" deep
99 suburban
alpine 9886 deck
kenwood 11 band eq
jl in rear roof
1 FI Q 18" with bp
Iraggi 220 ho alt
looks nice, especially for a first box. should sound great with what your using it for
thanks james, today was obviously a better day for me cutting those holes lol.
99 suburban
alpine 9886 deck
kenwood 11 band eq
jl in rear roof
1 FI Q 18" with bp
Iraggi 220 ho alt
Split :/...
Looks good though.
what? there is no split?
99 suburban
alpine 9886 deck
kenwood 11 band eq
jl in rear roof
1 FI Q 18" with bp
Iraggi 220 ho alt
looks pretty good :good: i used a jigsaw too, it takes alittle longer to cut the holes. hey you work with what u got, right.
I think he is talking about on the inside of the port, in the picture it looks like a small split at the bottom.
Very nice for your first box bro!
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
ah i see the split now,fudge well only thing i can do is add some glue on it, shouldn't be a problem though. thanks klown.
99 suburban
alpine 9886 deck
kenwood 11 band eq
jl in rear roof
1 FI Q 18" with bp
Iraggi 220 ho alt
