tequila Posted April 5, 2010 Report Share Posted April 5, 2010 How far should an aero port be from the back wall of an enclosure? Would this be the same rule of thumb as a slot ported box, distance = width of the port? Ive been looking at going aero ported to save a little net size compared to L-Slot ported boxes.. Thanks Quote '99 Civic hatch 18" AA Chaos - 7cuft @ 34hz - 114sq in. port Mac Audio Fearless ~ 1000wrms @ 2 Ohms Videos: Youtube Link to comment Share on other sites More sharing options...
bobonit Posted April 5, 2010 Report Share Posted April 5, 2010 1/2 the diameter of the port at a minimum. So for a 6" aero, 3 inches from the wall minimum. Quote 97 Maxima SE Bunch of shit going in, check out the build Build Log Link to comment Share on other sites More sharing options...
tequila Posted April 5, 2010 Author Report Share Posted April 5, 2010 1/2 the diameter of the port at a minimum. So for a 6" aero, 3 inches from the wall minimum. Would there be a noticeable difference if for example with that 6" aero i had 4-5" away from the wall instead of 3"? thanks! Quote '99 Civic hatch 18" AA Chaos - 7cuft @ 34hz - 114sq in. port Mac Audio Fearless ~ 1000wrms @ 2 Ohms Videos: Youtube Link to comment Share on other sites More sharing options...
blazron22z Posted April 5, 2010 Report Share Posted April 5, 2010 i heard the diameter of the aero so if it is a 4" aero it should be atleast 4" away from the wall Quote Link to comment Share on other sites More sharing options...
bkolfo4 Posted April 5, 2010 Report Share Posted April 5, 2010 Would there be a noticeable difference if for example with that 6" aero i had 4-5" away from the wall instead of 3"? thanks! It is the minimum distance, not max. More is better. . . If I was using a 6" aero, I would stay 5-6" from the back wall. Quote Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
