hey i would really like some help in buliding a spec box for these subs
2 x 15" Starsound ssw 381
spec on subs :Starsound Carbon Series 15" 380mm
2000w peak power
1000w RMS power
2.5" Aluminium Bobbin single voice coil
Treated cellulose cone
Rubber surround
Carbon fibre Dust cap
Sensitivity 89db/spl
Independence 4ohm
1 x targa 6000watt monoblock
1 Ohm RMS Output @ 0.05% THD: 2000WRMS x 1
Maximum Output Power:6000 Watts
Bass Level remote Control (16.4ft):YES
Low Pass Filter (Variable):N/A
High Pass Filter (Variable): 80Hz - 1.2kHzSubsonic Filter:20Hz - 50Hz
Frequency Response (-1dB):20Hz - 250Hz
Signal To Noise Ratio ('A' WTD): >100dB
Input Sensetivity: 200mV - 6V
Input Impedance:22k Ohm
Operation Voltage (negative Ground): DC 12V
1 x 3300watt 4 channel playing 4 sets of splits
i got these items as a gift would ne1 plz advice on how to bulid a very good spec box
so i can get a good DB nr while playing my sound everyday
im using it in a opel keddet cub 4 door
height till back board 52cm
length 98cm
widht from back seats 80cm
thanx
u4ria
Edited by u4ria
This is just a generic size for em since i can't find any real info on them.
H-45.72cm
L-96.52cm
W-60.96cm
You will need 2 ports for the box and the tuning will be 33hz.
Port Diameter - 6" or 15.24cm
Port Length - 35.56cm
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
from what I found these would be better in a sealed box 2cubes each
On 4/20/2010 at 10:06 PM, 'cc_audio' said:
Guys are just like girls, once you've had 18 inches you don't go back.
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
Sub Amp- (2) PPI 5000BD.1
(2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
(2) 1.5" Bose Tweets
(1) JY 80 AH w/ new JY busses
(1) Duracell 750 up front
Apex Alternators 270
A.C. Delco 160 alternato
H-45.72cm
L-96.52cm
W-60.96cm
hey thanx for the info let me know wat info u need i try and organize it
thnx
