Sundown SAZ3000d on one battery and alt?
Do you think i could run a sundown saz3000d on a stock battery and stock alt? If not what do you recommend?
Surly a vew minutes, have to do if u run on 4, 2 or 1 Ohm.
"in the abundance of water, the fool is thirsty" Bob Marley
For a few seconds, before the car shuts off. it'll pull so much amperage off the alt and battery the ignition coil will lose too much power and won't ignite the fuel lol
No won't happen. It could but I wouldn't dare it. But to help, depending on the size of your stock, you could add two rear batteries for support. I have a stock 160 alternator, duralast front, and two deka 9a31s for the back and she loves it...lol
2003 CHEVY TRAILBLAZER
AKA The Batmobile
Pioneer 6000UB
Sundown SAZ-3000D
2 Audio Q HDC3's
40' of 1/0 Gauge
2 Big Rear Batteries
A 38 HZ Box
KICK ASS!
Oops double post....
AKA The Batmobile
Pioneer 6000UB
Sundown SAZ-3000D
2 Audio Q HDC3's
40' of 1/0 Gauge
A 38 HZ Box
KICK ASS!
What the hell are you all on about.
I know someone who is running a Atomic AT-3000.1D (Exact same amp as a SAZ-3000D) on a stock battery and a stock alt ~110A alt with a single run of 0 gauge. Big 3 done. I think he gets voltage drop to like, 13v. No problems at all, except the battery goes flat pretty fast if he beats it without the car running.
I wouldn't try it with the amp at 0.5 but shit, it's not going to make your car switch off and your amp explode within 10 seconds.
10.x volts fo' life!
true that im running my saz 1500d at 0.5ohm on a stock electrical with no problems. Never below 12.7-13 It pulls some current but as long as you dont bump at idle alot and watch your voltage you could pull it off. I wouldnt recommend it to most people though. If you know what your doin you can do it for some burps with no problems i bet.
6 Sundown X 15s
2 Sundown NS1 V2s
C Pillar 4th order
Bagged Suburban on 24s
http://youtube.com/tlee333
Upgrade the stock front battery, do the big three, put a battery in the back..... You'll be money.
To be safe, you should plan on spending at least 1/2 the value of your amp on electrical. Anything else, you're just asking for your equipment to fail.
  • Who's Online   0 Members, 0 Anonymous, 1224 Guests (See full list)
