yeah it really depends on what your gunna power them with 2000watts, 3500watts+, you can power 1 15 with a ton of power and it might be as loud as 2 powered poorly
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
you will notice it a bit. maybe a slight more tickle of the ear but that about it. especially in the lower db ranges. so he is correct. you wont hear that much of a difference. there will be a difference but not like night and day
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
im pretty sure for both of them it was a 2000 watt alpine amp
bro thats perfect. 1000rms per sub. just make sure you dont get a shitty small box. itd be louder if you got a big box for 1 sub then a small box for 2. make sure to get the box to specs. should be slapping :D
idk if the box is to specs
i was just going to buy the box with my subs and amp and all that
so im assuming it is?
and a buddy was saying something about i would need to put another battery in if i put two 15's in?
  • Who's Online   0 Members, 0 Anonymous, 1629 Guests (See full list)
